Question about Canon Office Equipment & Supplies
Suggestion we have a canon printer model no.F257600 and a regular customers of around 4000 customers we need to print address stickers of our customers by every month can we print address stickers on your canon printer or not tell me frankly awaiting your answer thanks Mr Vyas
Yes
Posted on Sep 24, 2012
jackboy
  • 2985 Answers
SOURCE: printer driver
Where is the Disk that came with the printer? Have you tried the Canon Download site? You mentioned a 'List' which list? What operating system is this for? More detail please.
Posted on May 23, 2007
  • 390 Answers
SOURCE: MP460 printer--problem w/ envelopes
You seem to have clogged nozzles/printhead. Take out cartridges, do a thorough clean down where cartridges sit, the printhead, even the roller as well. Run your printers own cleaning maintenance before you do it manually with cleaning solution. Problem should be gone when you reinsert cartridges. Don't froget to reset ink levels and cartridges. good luck!!!
Posted on Aug 31, 2007
SOURCE: canon printer
I have done all that and is still coming up as wrong cartridge
Posted on Apr 20, 2008
SOURCE: Canon Printer Problems
Open the printer, locate the absorber, wash it, then centrifugate to get it dry, install it again and reset the printer.
The absorber is like a sponge filled with ink when it's used.
Posted on Apr 30, 2008
Gurudristi
  • 98 Answers
SOURCE: re Canon Pixma 4000
Canno ip 4000:
please go to the maintenance tab.
This you will find if you try to print anything.
In the print box >go to properties>go to maintence
Here the following Maintenance option are there:
cleaning,
deep cleaning,
Head Alignment,
Nozzle check.
Before your start maintenance, please check whether all print tanks have ink in them
Do a Nozzle check first, this will indicate where you have the problem. Once identified, you can do a color cleanig or a deep cleaning.
Do a Nozzle check again.
You could repeat this cycle about three times or so.
If your problem still persists, then its probably the Print head with jammed nozzles.
Please let me know whether you could solve it.
Please do rate this solution and thanks for using FixYa.
Posted on Mar 04, 2009
Please help me print round custom stickers. I use paper stickers to print them at home but the ink isn't compatible with the paper. What should I do?
What ink do you use? The right sticker paper will depend on the type of ink you're using. But if you want to spare yourself from all these troubles, I suggest just ask any online printing company to print stickers for you. Believe it or not, it's way cheaper and more practical.
Feb 27, 2012 | Office Equipment & Supplies
I need to print custom oval stickers. I need them to improve the packaging of the home-made jam I'm selling. But my printer won't cooperate. Do you think it's better if I ask help...
I think so. Asking companies to print stickers for you means you don't have to go through all the trouble. They are only one call away to get orders processed and the custom oval stickers printed. If you're already decided, I suggest this site: http://www.printrunner.com/sticker-printing.html
Feb 27, 2012 | Cars & Trucks
Connect Ubuntu box to HP LaserJet 4000 (printer #2 - LPT2)through Hawking print server model HPS12U (internal address 192.168.1.4) Same box (and other winxp pro boxes) connect and print fine thru...
Go to System > Hardware > Printers.
Then click on Server from the Menu, and then select Settings. Check boxes:
  1. Publish shared printers connected to this system
  2. Allow printing from internet
Click OK, then click Refresh.
You can click New to add the printer, it will search and then you select Network Printer, and find a network printer.
Feb 15, 2010 | Canonical Ltd. Ubuntu
Can't print custom paper size on HP Photosmart C6180
Printing anything other than 8.5" x 11" I have found challenging but there is a way around it. When you are ready to print select Print and go to
"Properties" button beside the name of the Printer.
Select normal for your print quality,
Paper source select Main Tray,
in resizing options select the size you need. In this case you would make a custom or perhaps the Card Envelope 4" x 6"
Select "Scale to paper size"
under the Resolution button there is a box "Show preview before printing" I select that so that I can see for sure before printing that it is recognizing my special paper and not the usual 8.5 x 11 sheet.
If it all looks good and it should, START PRINTING
You have to do this everytime you want to print a special size paper. If you print a lot of this size of paper custom name it something easy like your name"Krissy card env" so you can find it quickly and remember easily the process you follow.
Jan 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
CLC 4000 - Looks like Scratch marks in printed sheets
Is it from the copy board glass or the printer part? Doses it show up in all 4 color making a neg copy in each color. If it shows up in the same spot on each color it could be the opc or transfer sheet. Also does it repeat it's self down the page.... Marks can come from one of three places.... opc,transfer,fixing... Need more info...... To broad of a Question
Jul 23, 2008 | Canon CLC 4000 Copier
Canon IP 4000
I suggest that you set the printer to print B&W only by some setting on the program on your PC or computer.
Jul 01, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Won't print on normal paper
Refer to my previous post about manual under head cleaning and follow the routine through. This will most likely get you going as sounds like classic blocked nozzles. http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Jul 01, 2007 | Canon i860 InkJet Photo Printer
506 people viewed this question
old marine
old marine
