Question about Maytag Neptune MAH5500B Front Load Washer
Spins very slow belt apears good does not drain well
  • Maytag Master
  • 909 Answers
It is slow to spin because the water and clothes are to heavy for high speed. You need to open up the pump housing to get to the impellar and check for any obstructions. If clear, check the pipes for any blockages and remove. Once that is done, it will work normally again.
Posted on Sep 16, 2010
Wont spin
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
My washer starts of just fine but when going in spin cycle its slow and wont drain belt looks good,its just looks like the motor wont go into high speed
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
The spine cycle seem slow need to run more then once
check the tub to pump and pump to drain for blockages of debris,the pump should drain the bulk of the water,then it should spin out the rest unless the belt is that glazed,get to the spin cycle and pull out the washer drain hose out of the house drain stand pipe and see how much force water is while being pumped out while just pumping and not spinning,there should be the water stream the size of the inside of the drain hose and good velocity of water flow to the drain
Mar 13, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Maytag washer MAV208DAWW does not spin out the water completely from clothes after spin cycle.
do you smell anything burning or a burning oder,your belt could be glazed from over loading the washer and now the belt is slipping,also check the drain hose for kinks making for a slow drain,do you hear any noises when draining like something could be stuck in the pump, maybe to much detergent and it's oversudsing, or you could have a bad trainy,check the belt first belt part number is 21352320 and it's around 25 bucks
Feb 26, 2010 | Maytag Washing Machines
Slow spinning wet clothes
The reason to this problem is your worn belt.It might have
gone bad.You may need to replace it.
Sep 02, 2009 | Admiral AW22 Top Load Washer
Washer spins but too slow
Clean out the drain pump. Sounds like water is pumping out too slow. This added weight is slowing down the spin.
If water is pumping out OK and you still have the same problem, replace the drive belt.
Apr 01, 2009 | GE Washing Machines
Spinnig slow sqecking noise
This is joyce
sounds like the belt needs to be tighter. sounds like its slipping on pully. that may be why its not spinning correctly.
thanks
joyce
Feb 06, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Spinning slow and smells like burnt rubber. Draining very slowly.
Pull drain plug at bottom of machine put tray under it check belt
Dec 18, 2017 | Amana NAV2330AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
90 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
