Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer spin cycle doesn't work. Could it be the switch
  • oldguy5 Sep 16, 2010
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
    removes most of the water) machine.
    First, see the Sears parts site for your washer: http://www.searspartsdirect.com/partsdir...
    Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
    Four possibilities: (Ranging from easiest to messiest) None of the suggestions are very expensive.
    Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
    Older models only used the switch during the spin cycle.
    Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
    This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
    https://secured.whirlpool.com/Service/Sr...$FILE/L-55.pdf
    It also has a troubleshooting guide.
    To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
    Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
    http://www.american-appliance.com/catalo...
    With the jumper in place, try to re-start the washer.
    If it works, the Lid Switch is a relatively inexpensive part.
    If the washer still doesn't work, check the motor coupler.
    Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
    It's used as a fail safe device and consists of three parts.
    Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
    transmission input shaft. Between them is a rubber piece with six holes.
    The power from the motor is transmitted through the rubber piece to the transmission.
    The other shaft on the motor directly drives the pump.
    If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
    spinning.
    See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
    If the coupler looks damaged, it's a relatively easy fix.
    Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
    Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
    Put the rubber piece on the transmission plastic piece.
    Replace the motor mounting plate.
    Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
    Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
    Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
    If the motor coupler is OK, the problem could be the clutch:
    Sears has a replacement clutch band kit.
    See the following for how to pull the pump, motor and transmission.
    You DON'T HAVE TO PULL THE AGITATORS OR TUB.
    Also see the Whirlpool / kenmore service manual for these washers.
    Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
    See the Following Whirlpool parts list for alternatives to the Sears part numbers.
    http://shared.whirlpoolcorp.com/assets/p...
    If you've tested the Lid Switch and the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
    See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
    WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
    https://secured.whirlpool.com/Service/Sr...$FILE/787772%20%234.pdf
    Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
    When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
    Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
    In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
    You don't have to remove the drum.
    Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
    Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
    Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams.
    If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
    If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
    As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
    COUPLER OR CLUTCH OR NEUTRAL DRAIN:
    Three possibilities: since you can hear the motor (Ranging from easiest to messiest) None of the suggestions are very expensive.
    spinning.
    If the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
    Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams and spin gear.
    If that's the problem, install a Neutral drain kit or spin gear, put everything back together carefully and the problem may be solved.
    THIS IS POSTED AS A CLARIFICATION REQUEST SINCE FIXYA ONLY ALLOWS RELATIVELY SHORT ANSWERS.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Could be the transmission. Google your model and transmission. Rebuilt ones are 150.00 and can be replaced by a beginner in 2-3 hours.
Posted on Sep 28, 2010
No spin cycle
This is usually caused by the pressure switch. Here is a link with the other possible problems. To check the pressure switch follow the link to the video. http://appliancehelponline.com/topwashernospin.html
Jul 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore washer 80 series misses spin during wash.
You may need to replace the motor coupling between the pump and motor...
Apr 07, 2009 | Kenmore Washing Machines
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Kenmore 80 series
sounds like your control switch needs replacing.
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,452 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
