Question about Canon Pixma MP500 All-In-One InkJet Printer
Black strips when printing
After i changed the black print tanks in my printer i now have black strips across the front of any thing i print. i have changed both black tanks twice now. did all the different maintenance, nothing has worked
  • jcmi Jun 23, 2008
    I have the same problem. I can get the ink strips to disappear if I do the "Bottom Plate Cleaning" but that only works briefly. Also, the problem seems to be intermittent, as in it doesn't happen on all documents (only MOST). Possibly the ink cartridge is leaking? but i am still using the same brand as always and this problem just started.
  • Ria Gurl Jun 24, 2008
    I'm having the same problem, with the black strip printing on the back of each copy i make... Its very annoying. the circlular lil rubber piece that helps the paper feed out of the machine is wet with black ink. theres about 5 lil rubber things that feed the paper out and ONLY one of those seems to be wet with black ink, so everytime i print, it appears on the opposite side of my document. If someone knows how to fiz this problem, PLEASE PLEASE get in contact with me. My name is Maria M. and you can reach me by e-mail smilz922@aol.com
    Thanks
    Maria M
Thanks
Maria M
Posted on Jun 24, 2008
Is there a way to open the paper path on Canon PIXMA MX340
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Apr 18, 2012 | Canon PIXMA MX340 Wireless Office...
Yellow light keeps flashing underneath triangle- Error code 6480. Please advise what this means? many thanks
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also will fix a gap in the printing running lengthwise (not across the page like a clogged head).
Mar 09, 2011 | Canon MX700 Office All-In-One InkJet...
I have canon mp145 printer. when it starts to print it gives the service error 5100 message
Tried greasing (actually WD40) per linzi's reply, but it did not help. In the process, I think the solution presented itself. There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 27, 2011 | Canon MX700 Office All-In-One InkJet...
How to solve the error 5b00 for mx700?
Oct 05, 2010 | Canon MX700 Office All-In-One InkJet...
Error code 5100 on mx700 printer
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This part is related to the optical encoder which tells the print head where it is. Look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start up sequence. Softly clean this strip with a damp lint free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 28, 2010 | Office Equipment & Supplies
Getting printer stall code on screen...
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
To self-test the printer, please follow the steps given below:
1. Press and hold the "Plus" (+) button. While holding it down, press the "Scan" button. Once the screen changes, release both buttons. The screen will display the firmware version until the buttons are released. Then it will display 0: Button test.
2. Press the "Plus" (+) button once. The screen will display "Single Test Page."
3. Press the "Menu" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 03, 2009 | Lexmark X5250 All-In-One InkJet Printer
I have a canon MX700 and it is showing error code 5100, I looked it up in the manual and there is nothing for this code..help!
Try this.....
Sep 09, 2009 | Canon PIXMA iP90 Mobile Printer
Paper feed and colour problems with Konica Minolta bizhub c250
any stripes are usually caused by imagining unit, first use the tool in front cover to clean laser glasses. inspect IU drums for stripes maybe youll need to change them. is the page coming out ok, but picture is printed crookedly ?
Apr 17, 2008 | Konica Minolta bizhub C250 All-In-One...
Canon Pixma MP500 All-In-One InkJet Printer Logo
94 people viewed this question
old marine
old marine
Corne Viljoen
