Motherboard batery need replacement. Where is located?
    Novelist:
  • 113 Answers
on most motherboards the CMOS battery is a small silver disc no larger than the size of a U.S quarter dollar coin (actually a little bit smaller).
The battery is typically mounted in a slide in holder. Simply slide out the battery when the computer is shut down and then replace it ensuring you match the battery polarity when you put it back in. For eg if the flat battery has the positive side facing up (indicated by a + symbol) make sure the replacement goes in the same way.
These flat disc-like batteries are quite similar to the batteries found in some larger watches and are easy to buy at most computer shops or electronic shops. Most batteries fitted in motherboards start with the letters CR and are followed by 4 numbers. eg CR2016. The number is clearly visible on the battery. You might have to buy an equivalent if you can get an exact match. If you need some more help just ask me.
Thanks, Steve
PS Please vote for my answer or add a testimonial if I have helped you.
Posted on Sep 16, 2010
Where is CMOS batery?
above is an image of your motherboard and the location of the cmos battery
Aug 06, 2014 | Shuttle MV43N Motherboard
WHA IS MODEL MY BATERY BOARD
The 2032 battery is the standard cmos battery for all modern desktop motherboards.
Aug 18, 2012 | Computers & Internet
Will power on, but no response to moniter, key board or mouse. power button will not turn pc off. was told its the motherboard is bad. would like to know if ishould just get a replacement motherboard or if...
first try to reset your mainbord bios. disconeck from power source , an on the mainboard u got an 3v batery , get it out for 3-5 minutes , after thath try to start your machine withm the batery out.
Feb 02, 2011 | Computers & Internet
Where is the CMOS battery located?
On most desktops, it will be located on the motherboard, sitting in a slot socket. These batteries look like nickels and sit in the socket with their positive side up. They are usually held in place by a tension spring.
If you have a laptop, then the battery maybe accessible through an access door on the bottom of the case. These batteries can also be a disc type battery sitting in a slot or it can have a special covering with a small cable attached to it, this small plug attaches into a socket. In some cases, the laptop has to be disassembled in order to remove or observe the battery.
Jul 31, 2010 | Computers & Internet
Computer does not recognize battery
I know exactly what the problem is. The problem is that the motherboard is not reconizing the charger.The motherboard will need to be replaced along with the charger. I recommend calling Dell Costomer Service. That number is 1-800-847-4096.
Jul 21, 2010 | Dell Inspiron 1525 Notebook
I have an m5310 and i have troubles with the battery charge i bought a new battery but is still the same , i plug the notebook to the ac power and batery start to load (the front green light is on ) after...
Try to perform power drain on the motherboard.
heres the steps:
take out the battery
unplug the power adapter
press and hold power button for 30secs
put the battery back in
plug in the power adapter
power on the computer
if same issue will happen then you need a battery replacement.
May 21, 2010 | E-Machines M5310 PC Notebook
My desktop compaq sent me a message stating that the time & date is not set and may b a result of a loss in batery power, ask m to correct date and time and if mesage persists I have to replace the...
you need to replace your cmos battery, you need to open up the casing of your computer. you need to look for the coin cell battery on the motherboard, there shoulb only 1 there, so you cant miss...
Feb 17, 2010 | HP Compaq Business d530 PC Desktop
Nokia6120c
change display ic or display
Apr 19, 2009 | Asrock K7VM3 Motherboard
Replace batery
This battery is located in a slot on the motherboard. It's been a while since I've had a 380 apart, and I can't remember whether it's on the top or the bottom of the board. Start by removing the keyboard, if it's on the top, you will be able to see it. If it's on the bottom, then you will need to remove the motherboard in order to get to it.
Aug 15, 2008 | IBM ThinkPad 380ED
Computers & Internet Logo
David Payne
David Payne
