Question about BenQ FP71G 17" LCD Monitor
Am facing a problem with my BENQ lcd actually its showing nonperest mode again and again.............am unable to do anything
    Champion:
  • 220 Answers
Your display settings to 800
Posted on Oct 07, 2010
  • Samir  Shah
    Samir Shah Oct 14, 2010
    I was saying you need to confirm by changing display settings to 800 >< 600.
    Samir
I've PS3 and BENQ 24'' (HDMI) why showing NONPRESET MODE? I can't see anything it just black. Who can help me with this please anyone
You need to lower your PS3 video resolution to the native resolution of this monitor, it is too high right now taht is why your are getting the message on the screen.
Start PS3 with lower resolution and go upfrom there.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 19, 2010 | BenQ FP91G+ 19" LCD Monitor
BENQ FP737S Monitor shows "No Signal Detected" on startup
first problem could be the hdmi cable you are using is loose or broken.second, the display mode you selected was wrong, try to go to desktop and right click and choose nvdia control panel and choose the nview display mode to use,select the only use one display(single)and apply.
Jan 27, 2009 | BenQ FP71E 17" LCD Monitor
Contrast decreases to Zero
Had the same problem recently with a Benq FP71G+. It was still under warranty so I called customer care and they sent someone who replaced the board inside that contained all the buttons. I saw that the board was very easy to remove. He just unplugged it, and plugged in the new one. And its a very small board so probably doesn't cost much in case your monitor's warranty period has expired.
Jan 19, 2009 | BenQ FP71G 17" LCD Monitor
BenQ Monitor ' Out Of Range '
check your resolution settings and change to 800><600 and try again.If it does not work at 1024><768 try loading monitor driver In display properties it should show BenQ FP731 instead of plug and play monitor.
Samir
Oct 29, 2008 | BenQ FP731 17" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Found them
If you are referring to the C5707 inverter driver transistors, you can test them in circuit with an ohmmeter. Usually one pair will show shorted although only one may be actually shorted. Normal procedure is to replace the pair that shows in circuit short. If you do not resolder the transformer connections your transistors will short again.
Monitor Mike
May 30, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq 24" wont comes back after sleep mode
Try to install the OS once again.
If it turn up the same again then it may be the logical board problem.
Apr 12, 2008 | BenQ FP92W LCD Monitor
BenQ FP591 15" monitor decides to die
Strange that both should show the same symptoms don't you think? Have you changed anything computer wise? Graphics card or resolution? Screeching noise is a puzzle too. How are they powered - internally or via a separate power supply?
May 31, 2007 | BenQ FP591 (Black, Silver) 15" LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
61 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
