Question about Nokia 3110 Cellular Phone
My nokia 3110c mobile phone has lost its software since a week i have got it done from a dealer and he fixed it but since then it is always getting switched of while i watch any video or while hearing music and once it get's switched off i doesn't starts again.
    Guru:
  • 317 Answers
This might be software problem these can be solved by formatting only so visit my below site
http://www.fixya.com/support/r5875102-format_nokia_mobile_phones_3110c_2700c
Posted on Sep 16, 2010
How to flash nokia 3110c mobile phone
Flashing Done using the Software to Remove the Network Lock,So you can use the Unlock code to remove the Network Lock,But Unlock software Leads to Data Lose,Get the Unlock code at
Mobile-Unlocker and Unlock it.
May 26, 2011 | Nokia Cell Phones
My mobile nokia 3110c is not working its software is not work mobile is only blink
get the software updated from an authorised nokia priority dealer.
Dec 28, 2010 | Nokia 3110 Cellular Phone
My mobile phone Nokia 3110c gets automatically switched of so i am unable to upgrade the software how do i upgrade with out switching on my mobile
Please note that Nokia 3110c does not support online firmware upgrade. Hence, I suggest you to take the phone to the nearest Nokia Care Centre to upgrade the phone firmware.
Note: all the data in the mobile will be lost during the software upgrade procedure.
Before submitting your phone at the Service Centre, you may kindly take a backup of the phone contacts data to the SIM (Subscriber Identity Module) card. If the phone supports memory card, take a back up of contacts, messages, images, clips etc. on to the memory card or on to the PC.
Good Luck.
Thanks for using FixYa.
Sep 04, 2010 | Nokia 3110 Cellular Phone
My nokia 3110c mobile phone software failed please give a solution.
my nokia 3110c mobile software is stoping at second boot
Sep 03, 2010 | Nokia 3110 Cellular Phone
Please sir give me solution my nokia 3110c music player is not found
tats the most often problem seen in 3110c. i too used tat model initially. it s due to some software problem. pls contact your service provider or mobile dealer. ter s no other go.
Jul 06, 2010 | Nokia 3110 Cellular Phone
Auto matic swich off
hi,
it is a common problem in the classic series of nokia phone...it is cause by corrupted software...try to turn off your phone then unplugged your micro sd ,then turn it on...observed your phone if it will switch off..if same status ,you need this tools ,flash file and gadget to fix your phone...
1.)fbus cable 3110c
2.)mx key dongle with ufs interface
3.)3110c flash file v7.23 (you will get it in this site.....http://www.lsdshka.narod.ru/firmware_nokia.html )
procedure..
connect the phone in mx key dongle using 3110c fbus cable ,open mx key ,tick bb5 then bus check ..if the phone is connected to mx key put the flash file ,mcu ,ppm and cnt ..before flashing the phone and everytime you do flashing always make a back up in pm section and rpl of the phone to prevent bigger damage...now it is safe to flash the phone .after the flashing is done inse the battery and test the phone...
if you have no gadget that i mentioned above ,dont do the programming in your phone..go to a expert mobile technician ti fix it..
thanks for trusting fixya and i hope it will help you..
Jul 01, 2010 | Nokia 3110 Cellular Phone
Gprs settings for nokia 3110c
which operator u use for the mobile connection. contact ur operator and then take the settings manually. then configure according to the said settings and try out whether it works or not. if not then take the phone to the nokia care for the software flashing and certainly u will get the gprs connection enabled in ur handset. i have nokia 3110c phone and i am using gprs connections from airtel and aircel. u will get it certainly just follow what they are saying if that doesn't work then take ur handset to the nearest connector store for the configuration of the gprs and have it done.......
Sep 15, 2009 | Handmark Software MobileLists (950142) for...
Formatting internal memory of nokia 3110c
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Jan 14, 2009 | Nokia 3110 Cellular Phone
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
