posted by Archangel_md on May 17, 2008
I have the power cables disconnected, but cannot seem to see how to remove the PS from the case
Solution #1
posted on May 24, 2008
Hi the power supply is secured to the cabinet by 4 screws on the rear of the cab if not open the side cover 1 or 2 screws could be holding it in place with metal clamps or locks which can be released by sliding it out .
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for System Power Supplies
Email this problem
Email this problem
This Problem Also Relates To:
GE (515PS1) Power Supply
GE (515R1) (515PS1) Power Supply
HP (380312-B21) (380312B21) Power Supply
HP (950-3473) (09503473) 120-Watt Power Supply
HP ATX-300-12Z (ATX30012ZBD) 300-Watt Power Supply
HP Bestec ATX-250-12ZD 250w HP Pavillion Zinfandel Power Supply Part 5187-1098 (ATX25012ZD) Power Supply
HP Compaq 175-Watt Power Supply
Can you Help with these System Power Supplies problems?
Power Adaptor for 500GB LaCie...
Hi, My LaCie 500GB Porsche USB... Answer This...
Lanier VoiceWrite EX won't come...
The on/off button will not work... Answer This...
Repair Service
Find System Power Sup. Repairman Near You:
