Question about Oreck XL Ultra Bagged Upright Vacuum
Oreck vaccum when i put a new belt on, the belt rubs the side of the wall of the vacuum gets real hot and busts. is there any type of washer fitting that goes on the vacuum to hold the belt in place? i dont know i need help thank you. you can reach me at
  • 1,673 Answers
The belt must not be running true to the pulley. You may need a brush roll, but also check the motor to make sure it isn't moving inward after the belt is put on.
Posted on May 20, 2008
Oreck roller brush problem
The belt is just stretched. Replace it with one from a vacuum store not a discount store they ARE different. It can happen easily. That's the only thing it could be.
Good Luck!
The Vac Dr.
The Belt:
More info on belts:
Oct 16, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Replacement belt Oreck UPR014T XL
Ok its sounds like you need a new brush roller and change your belt
Aug 13, 2012 | Oreck UPR014T XL Pro 14 Upright Vaccum...
I have an oreck xl and the vaccum wont hardly push. Is it the belt? The brushes aren't turning when I lay it on it side. How do you replace the belt? If you can give detailed instructions I would so...
On the side of the head you'll see a removable plate with one screw. Remove the screw and slide the plate towards the front until it's off. You'll see the belt.
Nov 05, 2010 | Oreck XL21 Bagged Upright Vacuum
Oreck Belts
Unfortunately this is a very common problem on the Oreck XL uprights. As you you noticed, there is even an extra belt storage on the machine itself, on the bottom plate. When a vacuum cleaner has to put an extra belt on the machine, this should be a clear warning sign that you're going to have replace belts.....frequently! Unfortunately this is just the nature of the beast. Since there is no height adjustment on the nozzle itself, the vacuum will lower until it hits the carpet, the carpet is the only thing that adjusts the height of the carpet attachment. On other vacuums you have the ability to raise and lower the brush head according to what type of carpet your cleaning. When the brushes are at the proper height, the belt is also running at the proper tension and strength on the brush. Since the Oreck doesn't have a height adjustment, the brushes have a lot more resistance to the carpeting, which is what leads me assume that's why the machine goes through so many belts.
Oreck XL's were designed for hotels. Their slogan used to be "The Hotel Vacuum for you Home" even. Anyone who has ever stayed at a hotel knows that most have a very low pile commercial grade carpeting. The Oreck XL does a fabulous job at cleaning low pile carpeting that doesn't have a lot of dirt to vacuum up (restaurants kill most vacuums, but especially Oreck). The problem is that the Oreck XL was originally designed for cleaning low pile commercial grade carpeting, and not to clean plush, piled carpeting. The Oreck's have a 4 AMP motor in them, and where as it's true AMP's don't equal suction power, it's safe to assume that a 4 AMP motor will not produce near the suction as a 12 AMP would. When cleaning low piled commercial carpeting, you don't need much suction power, even an electric broom can clean this type of carpeting.
Oreck however does do one thing right, and that's advertising. David Oreck is everywhere! Newspapers, TV commercials, internet advertising, direct mailers, and more. They spend so much money advertising their vacuum cleaners that everyone is familiar with their products. What most people don't realize is that the customer is the one gets to pay for all of the advertising that's being done! Through the power of advertising, Oreck has taken what should sell for a $100 electric broom, and turned it into a $600 full size upright! Dyson vacuums are the exact same way, a lot of advertising, but not much vacuum behind the price.
Chances are that if you heard about a product through a info-mercial, or a newspaper add, then that product automatically is going to be sell for more then it's worth.
Unfortunately I can't help you fix the problem with your Oreck continuing to burn belts, but I can give you a link to the belts on our site if you need to purchase them. We offer free shipping:
3 Oreck XL® Upright Vacuum Replacement Belts
If you (or your friend) would like a personalized recommendation of a good vacuum specific for your exact cleaning needs, please feel free to add a comment, or contact me, I'd be happy to help.
Chris J.
Apr 21, 2010 | Oreck XL2200 Bagged Upright Vacuum
I bought a replacement brushroll because the one in the vaccum cleaner is worn out.How do I go about putting the brush in the vaccum cleaner. Do I pull it out or do I have to unscrew the entire bottom...
Greetings from GoVacuum,
Make sure the vacuum is NOT plugged in. In order to replace the roller brush, you'll need to unscrew the 6 screws on the bottom plate of the vacuum cleaner. Oreck uses a Phillips Head screw, so you'll need to get a Phillips head screw driver to replace the brush.
After removing the screws from the bottom plate, simply pull up on the plate by putting your fingers into the open area where the existing brush is located. After the bottom plate has been removed you will have access to the roller brush and belt.
You can now just grab the roller brush and pull straight up on it. It's beneficial to change the belt of the vacuum when you're replacing the roller brush anyways. There is a spare belt on the actual bottom plate of all Oreck XL vacuums.
You'll notice that the new roller brush has two black square plastic caps on both sides of the roller brush. You can look on the outside of this black cap, and you'll see the words OLD and NEW. Rotate the NEW side so it's facing upwards, and the OLD side is the side that's down inside the vacuum cleaner, make sure that both sides have the NEW side facing upwards. You'll need to wrap the belt around the silver pin in the back of the vacuum on one side, and through the roller brush's metal pulley on the other side. The just stretch the belt with the brush inside of it, and place the black plastic parts back into the vacuum cleaner.
Congratulations, you've now just replaced the roller brush in your Oreck!
Please feel free to email me if you have any questions on how to complete this repair, or just request a clarification through this Fixya page. My email address is
If this repair solution was helpful, please be sure to rate this repair as helpful by clicking the 4 Thumbs Up icons in the top right hand corner of this repair solution.
Be sure to check out for all Oreck vacuum cleaner parts and supplies!
Chris Jones
Mar 16, 2010 | Oreck XL2000 Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL intellashield smells hot and smoky when operating. New bag and belt and no clogs. About a year old.
If it smells like burning rubber with white smoke its the belt make sure the brush spins freely. If its a electrical burning it will smell real bad you WILL be able to tell which then its a motor issue you can remove the bottom plate 5 phillips head screws opposite the motor youll see 1 screw remove it pry the duct out and look to see if there's anything stuck in the fan if not its the motor its self
Dec 17, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Generic problem for all Vacuums
Posted by FISHERMAN928 on Jul 06, 2008
Older Oreck XL, new belt, new bag, checked for clogs, does not pick up
as it used to, and, much harder to push, seems to grab or drag, why????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are a couple of things that may work. Depending on if you have the old style brushroll you can upgrade to a new style Oreck brushroll that has twice the brushes and will a work a lot smoother. Also, clean the bottom plate – get rid of any dust and dirt build up and then spray the bottom with silicone and let it dry after you have totally cleaned it. Always use Oreck genuine belts and to change the belt every 4 to 6 months for the best cleaning and store the extra Oreck belts in a Ziploc bag in the refrigerator, other wise if you have a new belt, gag, you have checked for clogs there is no reason why it should be hard to push, if the silicone does not work replace the bottom plate. Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 06, 2008 | Vacuums
Oreck XL Ultra Bagged Upright Vacuum Logo
133 people viewed this question
Top Oreck Vacuums Experts
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
