Question about Windsor SR12 Sensor Bagged Upright Vacuum
I have a bush 1700w hepa filter vacuum and need to replace the belt but I don,t know how to get into it ?
I need a belt for bosh extraxx 17 1700w hepa cycle tech .type vxvu170v00
Contact a local vacuum repair shop. This website doesn't sell parts.
Jun 26, 2017 | Vacuums
I need to replace the filters for my vacuum but I cannot find them for model NV502. Help!
Which filter are you looking for? Is it the foam filter in the bottom of the unit or the HEPA exhaust filter?. Ive found both on Amazon. Amazon com 1 Shark NV500 HEPA Filter Fits Shark Rotator Pro Lift Away...
Mar 23, 2016 | Shark Rotator Professional Lift-Away...
What would happen if I would take out both hepa filters from my rainbow e-series? I do need extra super filtering - previous versions didn't have it and it was ok... Hepa filters are not so expensive...
It won't hurt anything if you don't have a problem with the tiny particles that will be blown into the air. The Hepa filters trap small particles that can be unhealthy to breath. Most of these particles consist of human skin and hair, pet dander, dust mites, etc.. Many people are not bothered by these tiny particles. Others, like asthmatics, can have serious complications from them and the Hepa filters really help.
Nov 24, 2011 | Rainbow E series Canister Wet/Dry Vacuum
How do you get the clear plastic housing off to replace Hepa Filter on a Dyson DC 18 ?
Don't take the clear plastic housing off. The lower hepa filter is not meant to be cleaned, only the top filter needs to be cleaned, every three months. I just talked to the Dyson rep about the same issue.
Jan 23, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
Make sure your water basin is not cracked or broken, also.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Turns on but does not want pick up anything.Suction is good but the garbage does not go into cannister.
The reason it is not picking up is because the belt is stretched or worn. You simply need to replace the belt. you can get belts here:
Dirt Devil Belts
Feb 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Windsor SR12 Sensor Bagged Upright Vacuum Logo
254 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
