Question about Nintendo Super NES Console
When I turn on my snes, the screen just goes black.
    President:
  • 894 Answers
  • Blank Screen
    1. Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
    2. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
    3. Make sure the system has power. If not, go to the No Power Light instructions.
    4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
      Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
    5. There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
    If the above troubleshooting doesn't fix the problem, click here.
  • Other Screen Problems
    1. Make sure you are using only licensed accessories with your system.
      We find that video problems occur most when an unlicensed RF switch is used. Make sure the name "Nintendo" is molded onto the RF switch, as opposed to "for use with Nintendo." Unlicensed products are not fully compatible with our systems and may not work correctly.
    2. Check all of the system connections to verify that they are firm and correct.
      • For AV connections
        Remove the AV cables and reinsert them with a slight twisting motion
      • For RF connections
        Make sure the channel switch on the TV and system are set to the same channel (either CH3 or CH4)
    3. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to make sure it is locked in place.
      Important Note: Removing the Game Pak with the power ON will cause the Game Pak image to freeze on the screen. Press Reset to correct the problem. Always turn your system OFF before inserting or removing Game Paks.
    4. Slide the Power Switch on the Control Deck to the ON position.
    If the above troubleshooting doesn't fix the problem, see below.
Posted on Aug 22, 2011
M still getting a rainbow effect on my SNES, its extremely noticeable when the screen goes black or is a dark scene, when the colors go down the screen i get green bushes turning blue, blue water turning...
Well I think that there might be an connection problem with inside of the console like the 62 pinconnecter has gone bad or one of the chips is broken you should buy a new one if its that awful.
Dec 16, 2010 | Nintendo Super NES Console
Im still getting a rainbow effect on my SNES, its extremely noticeable when the screen goes black or is a dark scene, when the colors go down the screen i get green bushes turning blue, blue water turning...
Well the cartiage reader is bad and needs to be replaced or some of the pieces inside of the super NES console went bad then. You should buy a new one if its that severe and don't use it any more either.
When i turn my snes on, the tv screen shows scrambled pictures of the game for a second and then goes black but the audio works just fine. the music continues playing. ive tried three different cords....
Well try cleaning the game packs out with qutips and rubbing alchoal it sounds lIke a glitch then that can occure sometimes with the old consoles
Nov 23, 2010 | Nintendo Super NES Console
I am trying to get my old snes to work I plug everything up and when i turn it on the tv goes to a black screen i am using the original rf adapter that came with it model no:nes-003 nintendo rf switch. I...
Try the game with another TV to see if you will have same problem. If you do not have that problem that means the TV you are using is faulty.
Thanks for contacting Fixya.
Jul 06, 2010 | Video Game Consoles & Games
Black Screen
It might be your AV cable or the connector for the cable. Try it on another TV just to make sure its the SNES though.
Jun 30, 2009 | Nintendo Super NES Console
Picture is only black screen with white lines
Are the console and the TV both tuned to Channel 3 or Both to Channel 4. On the SNES there is a little switch on the bottom of the back labelled 3 on one side and 4 on the other.
May 31, 2009 | Nintendo Super NES Console
Super Nintendo games start but levels don't
try blowing inside the game cartridge and then the slot the game inserts into. I had this problem on my snes with some games and this helped. Other to that it may be the console is on its way out.
Ebay sell some really cheap snes consoles now. I picked one up for £15.00 with games.
Nov 15, 2008 | Nintendo Super NES Console
N64 Console
try using the cables instead of RFS's
Apr 01, 2008 | Nintendo 64 Console
SNES Game/System incompatibility?
check your connections, try cleaning your snes system with some rubbing alcohol (the party where the game connects to the system), you might have to take it apart to do that...
one way we use to do with the NES was cut a piece of paper out to fit inside the game, make it wet with rubbing alcohol, then push the game in and pull it out a few times (of course if the paper gets stuck you'll have to take it apart to get it out.
SNES's are pretty cheap so u may have to purchase a new one
Jan 06, 2008 | Nintendo Super NES Console
Nintendo Super NES Console Logo
388 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
