Question about Cell Phones
When i turn on my blackberry curve 8520, it says app error 523 and has a reset option... but when i click reset it takes me back to the same thing
  • 358 Answers
Hi, there are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Posted on Sep 16, 2010
2 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: App Error 523. Blackberry curve
App Error 523 is a software hiccup usually caused by a 3rd-party application that is not compatible with the BlackBerry device OS.
Follow the below steps to get rid of this error message: 1. Take the battery out and put it back in after 30 seconds or so
2. While the device is rebooting (or while the hourglass is still spinning), plug it into the PC
3. Then open the application loader and remove the 3rd-party application that's causing the issue
4. Worst-case is when you need to wipe the device using JL_Cmder. Follow the instructions here:
http://www.blackberryfaq.com/index.php/How_do_I_wipe_the_BlackBerry_using_Jl_Cmder%3F
If every thing else fails, contact BlackBerry because the next problem that you might encounter is a database level problem.
Thank you and good luck!
Posted on Nov 20, 2010
Me blackberry says app error 523
It should give you the option to reset it. If not, take the back cover off, take out the battery, and put the battery back in. It should boot up automatically.
Mar 01, 2011 | RIM BlackBerry Curve 8520 Smartphone
I have a blackberry curve 8520 and i turn it on and dont let me write the pin!! and show an app 523 error reset! what can i do??
try this... plug in ur celfone in pc. run blackberry deskstop sorftware. click organizer.check calendar/memo/address book/task. then click configuring... step by step update online...
Jan 29, 2011 | RIM BlackBerry Curve 8520 Smartphone
How to correct app error 532 for blackberry curve 8520... I saw an uncaught error message for a second then it went away and now my blackberry curve 8520 has a white screen saying app error 523? then...
download a BB desktop manager ,install it and then connect your phone to the pc via the cable ,let the pc install the drivers o the phone be patient , your desktop manager will recognize your phone , there is one option name update device ,click on that and follow the instructions ur phone will be updated online and your prob will be solved , if u still need assistance mail me at cellphonez99@gmail.com
Dec 03, 2010 | RIM BlackBerry Curve 8520 Smartphone
My blackberry 8520 cure app error 523...
1. Install the software Desktop Manager
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader
3. Open Desktop Manager
4. Connect Curve 8520
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System
6. During the process, select YES to do a backup
7. The whole process should take about 1 hour
May 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
BlackBerry Curve 8520 Smartphone: when i turn on my blackberry curve 8520 it has a b...
just re install the blackberry operatind system software into ur fon from ur computer................and go on ....................or u can take off the battery and put it into again and press the return key when the red light goes off and till ur cell completly opens dont leave the return key..............it opens ur cell in safemode and u can deal with the error in safe mode
May 17, 2010 | RIM BlackBerry Curve 8520 Smartphone
How to fix blackberry 8520 app error 523
just wipe it or reload with the new updated OS
May 09, 2010 | RIM BlackBerry Curve 8520 Smartphone
I keep getting an app error 523, i removed all of
try a factory reset:
How to reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Mar 28, 2010 | RIM BlackBerry Curve 8520 Smartphone
Cell Phones Logo
436 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
