Question about Pioneer AVIC-N1 Car DVD Player
Disc wont eject
The disc comes out to the two spring switches that slide apart when iserting or ejecting a disc and sticks there. after a few moments, the screen will say mechanism error. I am able to get the disc out if I use something to slide the spring switches appart. Any help would be appreciated.
  • 38 Answers
Hi jamie,
It seems you have opened the top cover of your unit. Now take a dry cotton bud clean the roller which you can find right in front. Please do not use any liquid to clean the same.
Please cast your vote for me if this solve your problem.
ramesh22
Posted on Jun 08, 2008
How do I get a dvd out? the eject button wont eject the disc..
Ah! This is an easy fix! All you need is a bigger sized paperclip or something of that sort. You bend out one piece of the paperclip (a 90? angle) and push the paperclip Straight in the little tiny hole you can see on the disc door or next to the door. It will manually turn the gears to roll out the door.
Jan 26, 2015 | Audiovox ADV45 - 12.1 LCD Overhead Monitor...
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
DVD player wont eject
Try Turning the unit off and then back on. As soon as you turn it back on push eject .
Jul 25, 2009 | Audiovox VOD102 Car DVD Player
Mechanism error
If your unit is still making noise like it is trying to eject, then give it a little help by using a tweezer to pull the disc out after you pressed eject. Then clean the eject's mechanism rollers by using a couple of Q-tips and alcohol. Stick the slightly wet Q-tip into the center of the disc player slot until you reach the rollers after that slide it against the rollers from side to side, when you do that the sliding switches will trigger the eject mechanism and the rollers will start to roll. After afew times change the Q-tip and repeat. Allow 10-15 minutes for it to dry out completly. It should work after that. But if your unit is making clicking sounds or no sound at all right now and it display mechanical error message, then you have deep mechanical problems. There are services on Ebay for about $100, contact Rick for service. He own SAME DAY AUDIO SERVICES, he is very reliable. You can call me too:801-414-4566. Good luck.
Dec 31, 2008 | Pioneer AVIC-N2 Car DVD Player
Stuck DVD
im not resposible for anything here but try this. stick another disc in only about half way or as far as it will go up to that point. when the loading mechanism in the player sees another disc trying to come in, it pops up to accept the disc. it should spit your stuck disc back at you while holding the new disc in your hand.
Jul 11, 2008 | Jensen VM9510 Car DVD Player
Can you help? Stereo does not take in any discs
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
Apr 01, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
CHA 1214
After you remove the outer cover, you can see a small, spring-loaded black arm under the middle of the magazine. Just lightly push it to the side, and the magazine will eject.
Jan 23, 2008 | Alpine CVA-1003 Car Video Player
Jvc-avx1 wont eject
Try to power down the unit and the power it back up then press the eject button. If this does not work there might be a hole in the front of the unit which you could insert a paper clip which will actuate a mechanical release switch.The last thing you can try is to open up the unit and manually rotate the load and unload motor and this will eject the DVD. Restore the cover and then start up the unit to see if things are ok.
Sep 16, 2007 | JVC KD-AVX1 Car DVD Player
VM9511TS wont eject
Does it make noises like it's trying to eject? Like whirring motors?
Sep 10, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
EJECTING ERROR/LOADING ERROR
yes, i send it in to alpine and they adjust it for like $100 or so.
Dec 28, 2006 | Alpine IVA-D310 Car DVD Player
Pioneer AVIC-N1 Car DVD Player Logo
182 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
