Question about Dishwashers
What is the usual size of dishwasher for homes
  • 83 Answers
The standard opening is 24"x 341/2"
Posted on Sep 17, 2010
How do I remove dishwasher from housing need to get to antiflood device
depends on what brand of dishwasher and size
taking off the doors and frame and control board may be required
usually screws at the back will take off the outer skin of the machine
by doing that ...you should be able to get at almost all of the components
Jun 29, 2016 | Dishwashers
How use the dishwasher
Beata, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Basic Home Maintenance How to Use Dishwasher
How to Get the Most Out of Your Dishwasher
How To Operate Dishwasher Video Dailymotion
Mar 13, 2016 | Dishwashers
Hi, I need to find out the dimenions of my dishwasher or the number of the one to replace it?
Mobile home stuff is usually smaller house stuff is usually bigger but they just run different sizes just take the measurements of your old one and then check the specs over the computer of the new one or possibly look on Craigslist for a free one the same kind and slip it in
Aug 07, 2014 | Baumatic 23 in. BDW10 Built-in Dishwasher
Water not entering dishwasher
First check to see if water is getting TO the dishwasher.
Probably check the under-sink connection and see if there is water flow.
If there is, let's look for a problem with your water-shut-off valve.
This an electric solenoid, usually in the back or bottom of the machine, and it has the hose from under the sink hooked to it.
From it, there is usually a smaller hose going up to the dishwasher, most of them I have seen were black.
This solenoid should have a couple of wires attached to it, and is about the size of half your fist.
Sometimes they are blue in color.
These replaceable parts are usually good for about 7 years or so.
Be blessed.
Feb 04, 2013 | Maytag Dishwashers
Purchased Model # EWDW6505GS from Lowes in Tigard, Oregon today. It was the floor model and did not come with a manual for use and care (I got online) or with a drain hose. Where do I find a drain...
the drain hose for your dishwasher needs to fit the plumbing in your home. Measure the size of the connection at the drain (under the sink) and possible use the old hose as a model for what you will need. Lowes sells a hook up kit but be careful to measure the size of the outlet on bottom of the dishwasher and size and distance to the drain connection. Sometimes addaptors are used to size down the outlet side of the hose. Also if you have the manual it may show the size of the outlet on the dishwasher.
May 01, 2011 | Electrolux Microwave Ovens
There is not enough water pressure to properly operate. (House pressure is unchanged..)
Make sure you have the appropriate size inlet water line. if it is to small it won't provide the necessary amount of water. This is usually the problem, you may have a pump issue, but check the inlet line size first
Dec 22, 2010 | Kenmore Elite Stainless Steel 24" BuiltIn...
Buying a replacement panel for dishwasher
If you just need the panel you can try www.applianceart.com. They have custom cut dishwasher panels and a variety of covers for all size dishwashers.
Jul 16, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I would like to get a replacement filter for my GE deluxe 30 range hood
A few options for you:
These filters are usually washable. Unless the media is falling apart, they can be washed by hand with hot water and a good dishwashing liquid.
These filters have a metal media for fire safety and your local hardware or home improvement store will usually have this variety of filter media for a few bucks. You can then cut it to size and replace the media in the frame. If the frame is hot, this might not be an option.
You can contact the GE vendor (they may have a website) and find out where you can order a filter assembly,
Dec 15, 2009 | GE Deluxe 30" Convertible Range Hood -...
I don't have a problem, but would justy like to
Hello. Not all dishwashers have multiple panels which you can interchange. However, you always have two other options. One is to paint the white cover with stainless steel spray paint.
You can do this yourself with spray cans available from home depot, or you can remove the door and take it to an autobody shop to have it professionally done.
you can also have a piece of stainless sheet metal cut to size at a metal fabricating shop and use a construction adhesive to attach it to the front of your dishwasher, using stainless outside corner trim to finish the job.
Oct 25, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Dishwashers Logo
Top Dishwashers Experts
