Water is not draining from my front load washer. Not sure of model number could be GBVH6260 through WHDVH626. I'd like a set of drawings to determine how to access the pump and dishcharge system.
  • 1 more comment
  • MicheleF May 25, 2008
    we are having the same problem!!! GE front loader machine, not even 2 years old! Now, it is turning off and on during the wash also! UGH!!
  • Anonymous Dec 26, 2008
    Our also, turns off  mid wash and isn't draining!
  • smscheff Dec 26, 2008
    Us too!! ours turns off mid wash and is not draining!
Front load washers tend to collect debri in the drain path, particuraly thinks like coins, hair clips, etc. There is a large drain plug that has access to a filter. On this model, the lower front panel needs to be removed. You then see a large plastic valve that you can remove and get rid on debri. I need to clear mine every year. Warning, all remaining water in the tub will gush out, have towels ready.
Posted on Jan 14, 2009
Washer stops after wash cycle, does not cool down and drain water. I turn the knob to rinse it starts up again but does not drain the water. Help
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers. Series numbers (70, 80, 90) only designate the number of "Bells and Whistles" that a washer has and don't reflect the model number.
See the following for where to find the model number:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=21&osCsid=c73289e58485c8752675ae1a35ff796b
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Jan 13, 2011 | Kenmore Washing Machines
Ge whdvh626 washer fills and drains. drun does not
I took off back plate and noticed belt was off. I also noticed that pulley was very loose. I ordered new pulley and belt and replaced myself. Thanks.
Dec 16, 2009 | GE WSXH208A Front Load Washer
I need help getting the front panel off my frigidaire front load washer to clear blocked drain
If the model number is correct, this model washer's drain pump is accessed by removing the lower kick panel directly below the door. There are two screws holding it in place along the bottom front edge.
HINT: You may prop the two front feet of the washer up for better access to the screws (a 2 x 4 works well for this).
With the panel removed, locate the drain pump in the front under the wash tub. To clean out the pump on this type of washing machine, you need to remove the drain hose on the inlet side of the drain pump. This is the large black rubber hose that runs from the wash tub to the pump.
NOTE: Remove the clamp at the pump and clean out any debris in the hose and/or pump impeller. It is much easier to remove the clamp on the pump than it is to remove and reinstall the one on the wash tub.
HINT: If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum on the line to remove all residual water from the wash tub. This will save you from a mess of water to clean up. If you don't own a shop vac, you will need to lay down some towels to catch any residual water that remains in the wash tub and drain line. FYI: Residual water is normal.
If all these steps do not correct your drain problem, you will need to replace your drain pump.
A replacement can be found at pcappliancerepair.com for about $81. Just type in your model number and look under the "Motor/Tub" heading for item F35. Use the drawings provided as well to assist in parts location and assembly.
If you have questions, or if I have the wrong washer model, please post back and elaborate, so that I may assist you better. I hope you find this information helpful.
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Laundry comes out very wet
Hello tcburns07,
If possible, can you cycle a very small load of wash ( perhaps a towel or two) on the lowest setting to validate that : the washer is spiining up to normal speeds while draining water and that the water being drained is complete? Chancves are you have a either a blocked filter that limits water from completely draining, something in the drain pump or a restriction in your drain system. You could also have a worn belt that drives the pump. The test I suggested will at least determine if your washer is capable of draining all of the water from even a small wash load. Try that and let me know the results.
Regards,
Rick
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer Leaking from left front...
That would be your drain pump and/or drain hoses. You will need to access the inside of the washer by removing the outside casing to get a good view. The following link explains:
http://www.fixya.com/support/r397092-replacing_water_pump
The link explains how to replace the pump. Although you may not have a bad pump, it gives all the steps necessary to disassemble the washer to get to it. I would recommend you fill the tub about a third of the way then shut the washer off. This will fill the tub enough to determine where the leak may be coming from. Check both drain hoses for cracks or splits and make sure the clamps are tight. If the pump is leaking, it is NOT repairable. These are sealed units and will require replacing if damaged. You can purchase a new pump (if needed) at repairclinic.com. Just type in your complete model number and the pump should be listed as item number 3296 (part number 3363394).
This a simple job that requires not special tools to accomplish. I hope you find this information helpful.
Nov 14, 2008 | Kenmore 24032\24036 Top Load Washer
Why does my washing machine have 2 drain outlets?
This is a water saver or previously known as a suds saver model. The bottom one is the drain. The top one would go to a suds tub. If you set the machine on save, the wash water is pumped out of the top hose into the holding sink next to the washer. The rinse water goes out the bottom hose to the drain. The next cycle you could set the washer to the very beginning of the main wash cycle and the washer would pump the water from the tub back into the washer to be used as wash water for the second load of laundry. Yea, used water. But the first load would be lightly soiled stuff, and the next load would be old barn clothes or play clothes. It was designed to save water (about 65 gallons used for 2 loads vs. 90 gallons) and soap. (now, front load machines with larger tubs would use as little as 25 gallons for two loads.) Just hook up the bottom hose to the drain. Leave the save / drain switch set to drain and you'll be fine. To be extra safe (in case the switch was accidentally set to save) disconnect the wires at the solenoid where the drain hose splits into two at the back bottom of the washer. (right where the hoses exit the machine.)
Oct 15, 2008 | Washing Machines
It won't drain...
From your description, you could have a problem with one of several things.. You can run a few tests to determine the most likely area that is causing your problem ,,, If possible, can you unhook your drain hose from the drain and use a barrel to cycle water into ? (You can stop the washer any time to empty the bucket... Anyway, try running a wash load ( without clothes) and monitor the water flow... when the washer is pumping water out, you should have a fairly high stream flowing into the bucket. Using a bucket will rule out a clog in your house drain line...and provide d irect means to see how well the system pumps.. If the water is only trickling out during the drain process, then you have one of sveral problems.. The pump is clogged or defective, the supply from the drum to the pump is clogged and not allowing the water to be drawn into the pump or the outflow tube from the pump is clogged or crimped. Any of these problems will require you or a service person to gain access to inside the washer and diagnose the problem. I had a similar problem on an LG front loader and it was the pump itself.. One thing to remember is to use HE detergent for these front loaders.. and a very small amount of that.. Hope that helps...
Aug 04, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE FRONT LOAD WASHER NOT DRAINING
I see this is an old post, but if someelse has this problem I hope this helps. I had this same problem.
My GE front load washer (GBVH6260) has a filter located behind the front cover below the door. My manual makes no mention of this filter no is it obvious. Remove the three screws located at the bottom of the cover below the washer door, and remove the cover. You will see a what looks like a knob. This is the filter. Be sure to place a pan under it as best you can. If your washer is holding water be prepared you could get over a gallon, have some towels ready. Unscrew the filter and slide it out, it slides in the same way.
Apr 12, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
249 people viewed this question
Top Washing Machines Experts
