Question about Solis Crema SL-90 Espresso Machine
Solis Crema SL-90
No steam from steamer. I've located an internal plastic water tube that goes nowhere. Should this be connected or is it overflow? Not sure if this causes the problem.
  • 3,037 Answers
That plastic tube is most likely your problem it should be connected as there should be no overflow within the machine as this would wreck the machine. Were you able to find a connection for this tube at the bottom and top of the device? Please let me know, thanks
Posted on May 17, 2008
  • Benjamin Patri
    Benjamin Patri May 17, 2008
    If you can't find where this tube goes please let me know
    I can also provide you with the manufacturer's number incase the tube is broken or you need any question answered by them
    1-888-437-8340
    The hours are Monday through Friday 8:00 am to 4:00 pm PST
    Please get back to me on this tube. thanks
  • Benjamin Patri
    Benjamin Patri May 21, 2008
    Were you able to fix this, if so then please give me some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    thanks and Have a Great Day!
    Genius:
  • 3,422 Answers
Please CLICK HERE
I hope this helps..
Goodluck..
  • 796 Answers
Check whether the fuse is proper
  • isaac johny
    isaac johny May 17, 2008
    there may be some problem in the thermostat too
Solis crema sl 90 the steem is not work
Usualy this a goggle steam wand. So you can insert a thin steel wire in the seam wand and turn the steam knob slowly untill you see some steam come out. Keep move the steel wire and after you get the first steam try to boil a glass of water and leave it for ten minutes and then boil it again. This will clean the steam wand internaly.
Sep 06, 2011 | Solis Crema SL-90 Espresso Machine
Water is dripping from the head while using the steaming wand. It seems like a seal is bad--could that be the case?
first check the water supply which where is connected thru your machine and lastly the gasket which controlling volume of water thru your machine
Jan 08, 2011 | Solis Crema SL-90 Espresso Machine
Solis Cream SL90 not heating water
Yes, it is possible that the thermostat tripped or is damaged. If thermostat is not damaged then elements might be damaged.
Jul 02, 2010 | Solis Crema SL-90 Espresso Machine
Solis Crema SL90 not heating water
Yes it can be repaired, sounds like the thermostats might have tripped.
Steam works intermitantly, how do you get top off machine? Ive removed the one top screw but top doesn't want to come off. I have a solis crema sl-90. thanks!
Hi
Once you have the screw out, the top will slide forward. Don't try to pry the top up or you will break the mounts. The face will move with the top as they are connected. When you put the top back, the face slips into a grove in the top and everything slides back.
Feb 28, 2010 | Solis Crema SL-90 Espresso Machine
Steamer works but not water comes through coffee, even with no grounds in
there is a relay that is supposed to open a valve to let the hot water flow and the relay is not working. see if your coffee maker is still under warranty and take it for service.
Nov 13, 2009 | Solis Crema SL-90 Espresso Machine
Trouble installing replcement gasket in Solis Crema SL 70
SL 70/90 Brew Head Gasket Replacement Time 1 to 2 hrs Tools # 2 allen wrench # 1 Phillips screw driver # 2 Phillips screw driver # 13mm wrench First unplug the machine. Next remove the screw in the top back of the machine. Push the top forward with your fingers. This unlocks the top and it can be placed behind the machine with the wire connected. Next rotate the steam knob counter clockwise till it stops. Inside next to the micro switch there is a brown cam. On the backside of the cam is the #2 allen screw. Loosen this screw and the rotate the steam knob clockwise until it is removed. Now remove the clip on the steam manifold that holds the steam wand. There may be a plastic tie that is securing the clip. Cut it. Pull out the steam wand and let it rest on the bottom cover. Next remove the 4 large screws that hold the cover plate around the brew head. This will allow the cover plate to drop down and swivel on the steam wand, exposing the nuts that hold the boiler on the bottom metal plate. The nuts that hold the boiler on are # 8. Before you loosen the nuts you need to remove the water inlet nut on the side of the boiler. It is a #13 wrench. Remove the water line. Now remove the nuts that hold the boiler on.
Jun 16, 2009 | Solis Crema SL-70 Espresso Machine
Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Jan 18, 2008 | Solis Crema SL-70 Espresso Machine
Solis Crema SL-90 Espresso Machine Logo
113 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
