Question about Canon PowerShot A570 IS Digital Camera
The memory card on my Powershot A570 IS is locked. I have changed batteries @ memory card with no success.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Sep 16, 2010
Card locked unlock
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 28, 2013 | Canon PowerShot A570 IS Digital Camera
How do you take out a memory card from canon powershot A570 IS?
Open the card slot cover and push down gently on the edge of the card as if to push it further into the camera. The card will pop out a bit, allowing you to grasp it and pull it out all the way.
Jul 27, 2012 | Canon PowerShot A570 IS Digital Camera
CAMERA LOCKS MY MEMORY CARDS ,CANT USE
A locked memory card message refers to a small plastic switch on the side of the memory card. Take the card out of the camera and find the tiny plastic switch at its edge. Push the switch to the unlocked position and reinsert the card into the camera. It should work normally. This switch is used to prevent new photos taken on a card that contains valuable photos.
Please rate this fixya answer thanks.
Feb 19, 2011 | Canon PowerShot A570 IS Digital Camera
My camera says "card locked"
Remove the memory card and you will find a switch on the left side of the card. It must be locked, so slide or push the lock on other side to open it and then insert the card back to the Camera.
Regards
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Feb 11, 2011 | Canon PowerShot A570 IS Digital Camera
My Canon PowerShot A570 IS won't turn on. I put new batteries in and checked the memory card. What else can I do?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 19, 2010 | Canon PowerShot A570 IS Digital Camera
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
Camera says, Card Locked
The cause is most likely the tiny lock switch on the side of the memory card has been moved to the "locked" position. Remove the card from the camera and slide the switch to the opposite position and you should be good to take more pictures. If this solves your problem, please rate the answer favorably. Best wishes.
Nov 23, 2009 | Canon PowerShot A570 IS Digital Camera
Memory card error/card locked
It sounds like your card is locked. You need to unlock it. On one of the sides you should see a piece that can move back and forth. Move it from the position it is now to the other side. This should unlock your card. When locked the files are unaccessible to anyone. This also means that files on the SD card cannot be deleted while the switch is in lock position. When the switch is in up-position, then all files located on the card are accessible to anyone, and that files may be deleted from the card.
Good Luck.
Apr 07, 2008 | Canon PowerShot A570 IS Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
241 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
