posted by showmenow on May 17, 2008
need the code for the rca rcr311w please help, for a phillips magnavox.
Solution #1
posted on May 23, 2008
Magnavox codes: 0054, 0179, 0030, 0020, 0024, 0096, 0186, 0171.
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
- PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
- PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
- ENTER 9-9-1 (two blinks on the remote)
- ALTERNATE
slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.)
button until your device turns off. (On VCR, LD, and CD players use PLAY
instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes. - When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
- PRESS and HOLD the SETUP button until the red LED flashes twice.
- PRESS 9 - 7 - 5, the red LED will flash twice.
- PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
- PRESS the button that will receive the learned function, the LED will flash rapidly.
- PRESS the button on the original remote to be learned.
Cheers!
IrishDruid
Comment by IrishDruid, posted on Jun 01, 2008
This thread has gone 7 days or more without a response. Please close the thread with a “FixYa” or “Helpful” rating.
Or post back with latest developments, what steps you took, etc. and I will assist you further as best I can.
Thank you.
IrishDruid
Thank you.
IrishDruid
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Universal Remote Control DIRECTV
Email this problem
Email this problem
Can you Help with these Remote Controls problems?
Universal Remote Control DIRECTV Universal...
amigos tengo bloqueado mi...
el problema es que la tecla (ON... Answer This...
32 inch tv 2001 model
it has sounds but no picture do... Answer This...
need tv code for phillips model...
looking for a tv code for my... Answer This...
remote control
remote control
I have a Magnavox tv. I lost... Answer This...
direct tv remote- volume...
I'd like to program my new... Answer This...
Repair Service
Find Remote Control Repairman Near You:
