Question about Ruud UAKA030 Air Conditioner
Air conditioner blowing hot air
Turned on my air conditiner for the first time this year, it is only blowing out hot air, it is only a year old
    Genius:
  • 1,673 Answers
Make sure that all the controls are in their correct postition to function properly.
If all the settings are correct, a common fault is, most likely the compressor failed, or it leaked the gas out.
The air conditioner will need service.
Jerry G.
Posted on May 17, 2008
Low on freon,compressor not running,if its a heat pump could be reversing valve stuck,maybe heat strips are on
My Air Conditioner started blowing hot air. Code p2181 came up. I have had problems with my fuse box over my battery. Could this be the problem again?
  • Press the "Power" button to turn off your unit and then remove the filter from the filter panel on the side or front of your air conditioner. Refer to your manual if you are unsure where the filter on your unit is located.
  • 2
    Inspect the filter. If it is dirty, brush off dirt, debris and lint. If it is really dirty, wash it with mild soap and water and allow it to dry completely. Reinsert it into its compartment. If your filter is worn out or damaged, purchase a replacement filter from an appliance or hardware store and replace the old one.Turn on the air conditiner
  • Check for a reset button on your air conditioner and press it to reset your unit. Some of the newer air conditioners have reset buttons to restore the default factory settings. Press the "Power" button on the front panel of your air conditioner to power down your unit if it does not have a reset button. Unplug the unit from the electrical outlet. Leave the air conditioner off for several hours to see if it will reset.
  • 4
    Plug your air conditioner back into the electrical outlet and turn it on. If your air conditioner is still displaying the E1 error code, turn it off and contact a qualified technician because the room thermistor response to detecting room tempeture is needs replacement I say I'd loose business but rather clients trust me then go elsewhere recommend me for what you'll pay get a new one if it doesn't work
  • Sep 15, 2013 | Cars & Trucks
    My air conditiner does not want to turn on.
    Here is a tip about troubleshooting your air conditioner...
    There are many things that can cause your air conditioner not to cool...
    AirConditioner Trouble - Review the Possibilities
    heatman101
    May 31, 2011 | LG Goldstar GWHD5000 wall/window Air...
    Hi: I have a Carrier 38CMC42300 AC unit which will not turn on and the air handler is blowing hot air. The 40 amp breaker for the AC unit trips right away when reset. Could this be a condenser or motor...
    Your compressor or the start components are bad...
    Air Conditioner Trouble - Review the Possibilities
    heatman101
    Sep 30, 2010 | Carrier 38CKC036 Air Conditioner
    Our air conditioner unit turns on but just blows hot air
    our unit is realy a coleman unit but You did not have that listed.
    In any case it started back up again and I was so releaved as it was at least 103 degrees yeasterday. But i haove a feeling this may not be the end of it .
    I may need your service at a later date.
    Thank you for your quick response.
    Jul 29, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
    Brick Air blowing hot air
    if you hear the compressor turning on,no heat, the coolant has leaked out. if the compressor doesnt turn on, its a control issue.
    Jul 25, 2009 | Heating & Cooling
    When i turn the hot water tap on to get hot water the red pilot button keeps going on off and clicking , after some time runing hot it goes cold and the other warning light starts flashing. its a...
    Air conditioners do not provide hot water, and gas air conditioners are very rare. I think you would have better results if you post this in a different category.
    Jul 27, 2008 | Heating & Cooling
    AIR CONDITIONER COMES ON BUT DOES NOT BLOW COOL AIR
    It is possible that your unit needs refrigerant but Before I would have someone recharge it they would have to locate the point of leak and repair it. I would check to make sure it is not some other problem first, like is the compressor operating.
    Jun 15, 2008 | Maytag M6P09S2ACOM Air Conditioner
    Goodman 3.5 heat pump
    Does the breaker blow when you turn it on? If it does then the compressor is certainly shot. I would spend a couple of bucks and get a second opinion. As far as price $1500. is a pretty good deal for a new condensor.
    Jun 09, 2008 | Goodman CLQ36AR49 Air Conditioner
    My haier window air conditioner
    I have a haier unit and last night the led went crazy it has totally stop working now and the LED just shows E1 I have tried unplugging it and resetting the button on the plug and nothing has helped this unit is less than a year old. Please help if you can....
    May 18, 2008 | Whirlwind FH-778 Air Conditioner
    Ruud UAKA030 Air Conditioner Logo
    201 people viewed this question
    Top Ruud Heating & Cooling Experts
    Donni Steen
    Bill Long
    Tim Whalen
    Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
