Question about Quantum M1500 (m1-2/21-s6l) Super DLT Tape Drive - 2 Pack
QUANTUM M1500 error cleaning drive error code 263 C
2 Suggested Answers
IBeMad
  • 85 Answers
SOURCE: Fan Fail Erorr Fan:15 on m1500 Quantum DTL.
Replace broken fan, but before you do that open up your computer while it's running, and make sure all of the fan connectors are snug.
Posted on Jun 20, 2008
Error 99 when using Quantum Transceiver
Error code 99 is a non specific error code a sort of catch all. Remove the lens and clean the contacts (lens and camera), remove the battery and the memory card. Leave the camera in this state for about 10 mins, enough time to discharge any build up of charge or static. Reinsert the battery and the memory card and reattach the (cleaned) lens switch on leave for 5 seconds and press the shutter button to see if this has cleared to problem.
Jul 09, 2014 | Canon EOS-20D Digital Camera
Tip
Plantronics Passkey
The passkey is 0000 (4 Zeros) except for models M1000 and M1500 (see below for their number.)
For both the M1000/M1500:
Remove the battery cover from the headset and then remove the battery itself. On the Green PC board, you will find a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
on Sep 12, 2009 | Plantronics Bluetooth M1000 Consumer...
CHK 262D LIBRARY C LINE 4231 PATH0000
Power down the computer, power down the library, disconnect the library from the computer, power it up. If the problem remains try it again but this time without any loaded tapes. If it is still in the error state check with Quantum Support.
Jan 15, 2011 | Quantum M1500 (m1-2/21-s6l) Super DLT Tape...
We are having an issue with our backups. The system event log says there is an error 7 and lists the tape drive as having a bad block. However the quantum diagnostic tool shows the drive to be healthy. ...
Event ID-7 is a "Bad Block" on the Tape being using. By design, when a Bad Block is encounter, the Tape Drive "Seizes the Tape" and goes offline. It can sometimes be difficult to get the Tape Drive to release the Tape. Refer to the Users Manual for instrcutions on how to Reset the Tape Drive. Sometimes applying the Firmware Update willl reset the Tape Drive and Eject the Tape.
Do not assume the Tape is Bad, but do not re-use until tested. The Tape may be Bad, the Tape Drive may simply need Cleaning or the Tape Drive may be Worn or Damaged. If you are using 3rd Party Backup Software, such as Backup Exec or Yosemite, you wan want to check the Removable Storage Servcie to see if it is set to Manual or Automatic. Any Tape Devices would need to be first Deleted in the Library Section of Removable Storage, then Sop and Disable Removable Storage. Since Removable Storage is in effect NTBACKUP, this Service can interfere with the Operation of your Backup Software and generate "Bad Block" Errors.
To Test the Tape with your Quantum Tape Drive, use a tool called XTALK ( xTalk-6.4.1.1_Quantum_Setup.exe ) that is found on Quantums Website http://www.quantum.com/ServiceandSupport/Index.aspx
You may run a write_read_full Test on the Tape. Be sure to Clean the Tape Drive first. If it fails the Tape, try it with a 2nd Tape, If it fails again, suspect the Tape Drive.
OldCountry73436
Oct 04, 2010 | Quantum DLT-V4 DLT Tape Drive
What can cause a 2680 Error code on a Quantum M1500 tape system?
Drive 1 has reported a hardware error, Check with your drive 1 is it blinking with any amber led.
Dec 15, 2009 | Quantum M1500 (m1-2/21-s6l) Super DLT Tape...
Elem Table Bad (2B) error
The element error usually points to the drive, the best thing is to do is run the full diagnostics for the drive, and see what other hardware codes you receive, if it still points to 2b, then it is either the drive or the solenoid of the magazine failing. If you have a two magazine setup, just reverse the other magazine and test it that way.
Apr 16, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
I have a plantronics 330 and my phone says to enter bluetooth pin
Jul 21, 2008 | Cell Phones
Jun 18, 2008 | Quantum M1500 (m1-2/21-s6l) Super DLT Tape...
Quantum M1500 (m1-2/21-s6l) Super DLT Tape Drive - 2 Pack Logo
247 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
