Question about Refrigerators
Frost free swithes off after a few days . can be started after defrost
  • 51 Answers
LG elecrocool refridgerator not cooling
it is mos tlikely frosting up on the evaporator, this shows up as frost on the back wall of the freezer that means its not self defrosting, check the defrost system, defrost termination therms can go bad, and need replacement, defrost elements can short out, defrost board if it has one may be bad.
Feb 21, 2012 | LG Refrigerators
My upright freezer freezes everything fine my only pro.blem is that it builds up ice/frost on the ceiling of the freezer first and then works its way down i have taken everything out,started fresh and...
Since you didn't give a model number, I don't know if it is frost free or not. If it is, then you have a problem with you defrost system: defrost heater, thermostat or defrost timer.
It also sounds like your door seal is not making solid contact and most air is leaking into the freezer.
If your unit is a frost free, then water should drain down and out.
Jun 24, 2011 | Freezers
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Food defrosted in top of upright freezer
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost thermostat, heaters, or trimmer
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up
Hope this helpout and Good luck
Jul 28, 2010 | LG LRTP1231W Top Freezer Refrigerator
Bottom freezer model.. looks like shaved ice all over inside.. not sure why it is frost free...
u most likely have a defrost component out that is causing ice buildup. this will start blocking the flow of air and cause cooling problems. usually it will be one of 3 things. defrost heater, bi metal defrost terminator or defrost timer or on some units an adaptive defrost control. this problem takes about 7 - 10 days to start causing a problem. removing all frost behind panel will buy you as much time.
Mar 03, 2010 | Refrigerators
Freezer building up with frost
Sounds like the defrosting system has a faulty timer/board, faulty heating element or bad electrical connections to these components.
More info, let me know...
Charlie
Aug 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Is there a way to disable the frost-free feature on amana freezer
If you disable the frost free feature you will have to defrost every 10 days.
But, yes,it can be done.
Aug 05, 2009 | Kenmore 53542 / 53544 Side by Side...
Ice builds up on evaporator coils. After chipping off the ice, refrigerator is cold again. This lasts only a few weeks as ice builds up. Eventually, the freezer is cold but the refrigerator is very warmer....
Assuming this was originally a frost-free model, either the defrost cycle timer died or the defrost heating element died. If it's the timer, you might be able to manually start and end a defrost cycle every few days. If it's the heating element, you may be stuck with what you're doing or an expensive repair or buying a new refridgerator.
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
Freezer only freezing to 20 degrez
If the door was left ajar for any extended period frost has built up on the cooling coils. A complete defrost of the freezer should take care of the problem. Normally a frost free system will clear the ice from the cooling coil when the defrost time cycle happens. However frost may have built up in areas where the heaters can not readily remove it in a normal defrost cycle and shutting the unit down with the door open for about 24 hours should clear it out.
Nov 27, 2008 | Freezers
Icing up in bottom of the freezer
I don't know the particulars of your brand, but if it is frosting up Most fridges will have a bad heater element, a bad defrost timer (or controller if it is electronic) or most likely a bad defrost limit switch. This is a switch mounted on the inlet line of the evaporator with a clip and senses when the evaporater is defrosted so that it does not get too hot and start melting parts. This switch should have zero ohms of resistance when cold (below 40ish) and be completely open when above 40 or so. The easiest way to test it is take the wall covering the evaporater off and locate the plugs for the swiths. Test continuity through it. If it is sitting in ice, it should have no resistance. If it is open and in ice (infinite resistance) then it's bad.
Oct 05, 2006 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
