posted by bethcon on May 17, 2008
Can I get a new clean water tank for my Hoover? After filling tank, as soon as I lock it in water poors out even before I can start cleaning carpet.
Solution #1
posted on May 23, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Take the clean water tank off, and look at the underside very carefully. This tank is made of a very thin plastic, and chances are, your tank is cracked or broken. Sometimes the valves fail as well.
There is a new tank available, a single-piece tank instead of separate water and detergent reservoirs. The part number you want to look for is 42272104. The new tank does NOT come with a handle, so save your handle and use it on the new one.
Search for this new part number online and find the best price. I have seen them for around $40.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hoover SteamVac Carpet/Upholstery
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Hoover SteamVac Carpet/Upholstery Deep...
hoover steamvac
hoover steamvac
i cant get the upholstery hose... Answer This...
restrictive valve
restrictive valve
moments after starting the vac... Answer This...
when i fill the water
when i fill the water and soap... Answer This...
My carpet cleaner will not
My carpet cleaner will not pick... Answer This...
cant get upholstery part on
I know where part goes but... Answer This...
Repair Service
Find Vacuum Repairman Near You:
