Hi the error code 560 is for the BCU which is a control board for the machine it is not getting a signal from this unit...try this ...press the yellow clear button then enter 107 then hold down the stop/cancel button till the screen changes select copier sp then 5.mode use the arrows to select 810 sc reset execute this and turn machine off .. wait a few then turn back on, if the error was a slight missread it should work away but if the error comes back you may have to remove the back panel and check the connections mayb replace the board.. good luck A.
