Question about Garden
I lost my fuel cap what shal i do - Garden
    Brigadier General:
  • 3,911 Answers
Go to a small engine and/or mower repair shop and buy a replacement. Then wonder as to whether or not you should be permitted to vote or sign contracts.
Posted on Sep 16, 2010
04 pacifica.after filling up with fuel i lost acceleration. Then lost power steering.
It sounds like your timing belt may have failed due to the heat.
Jun 24, 2017 | Cars & Trucks
Does not start
When It has a fuel motor ? there is not enough oil insite the carter left is the state of the inflammatory stop button 0 forgotten ?set it to 1 is the oil protect damaged ? disconnect it temporary to try also if there is enough oil and try again also comes fuel inside the primerbulb if its on it. fuel filter control of sparkplug this shal gifs a healthy soft audible blue spark. and very important of all( is there enough compression present ?)
carburettor jet clean ? float chamber dirty.
If its a electric motor is this an induction motor and growls then a startup capacitor has left or if it has a auto-stop that lingers control the bypass on calcic also the 6 valves o-rings or Valves some of theme are fixed Liming then there comes no water .
Sep 19, 2015 | Garden
Problem starting after fill with gas
no year?
this car is a Daewoo car, in Suzuki snake clothing. it is. and are trouble cars.
correlation is not always cause. (its way more complex)
Im answering for Cranks robustly but will not start. RIGHT?
does car start with gas cap removed or loose.?
NO, then its not the cap, PERIOD.
the cap will fail not at fill ups, as that makes you remove it
this breaks the seal and with the wrong cap lets in the air.
and car start. the wrong cap with no vacuum breaker
causes lost power and stalls driving. (lost fuel pressure)
so why try to guess. why not do the simple tests. done now for 100 years. on all engines (spark , otto cycle engines)
1: check for spark. ????
2: check for flooding or lost fueling.
fueling:
spark tips (yes, remove and look) are soaked in fuel dripping
yup , flooded,
to unflood it crank with throttle wide open, called WOT. this cuts fuel
and flooded cars starts, (operators guide tells this......)
if spark tips dry, then its starving for fuel
so add some. ( a test)
this page works for most cars made,
http://www.fixkick.com/nostart.html
see what scotty does....... a video presented there
Mar 24, 2014 | Suzuki Forenza Cars & Trucks
1996 Geo Tracker gas cap has to be exact fuel pressure?
Old post. but this is common on ALL EFI CARS.
great question and is very easy.
btw one of the best posts on the forum best of 1300.
the gas cap must have the proper vacuum breaker (ask STANT for one) if missing the cooling fuel will pull and illegal vacuuum and the gas tank will implode (crush) I have a nice photo of same car doing that.
this vacuum also stalls the fuel pump, as the vacuum builds.
this happens on cooling day not getting hotter day.
to prove this drive with the cap loose and ignore the ECU check light for EVAP failure. (pressure test fails)
loosen the cap key on, 3 times to 5 times to build pump
pressure, the pump only runs key on for 3 sec. then start it up.
the other proof of lost fuel is the test fuel test. (spray)
to google landers. i make this. post.
Jan 18, 2013 | 1996 Geo Tracker 2 Door
How do I order a fuel key for jeep grand cherokee
go to nearest dealer and will have to purchase new fuel cap and they will be able to re-tumble new lock to your key and remove old cap
May 05, 2010 | 1999 Jeep Grand Cherokee
Nero 7 cd key no.
5C89-0000-1911-0000-4006-0794-9395
try that let me know//oz
Jul 28, 2009 | Ahead Software Nero 6.3 Reloaded (60096)...
1982 spider will not start no fuel injection
the injection relay,if memory serves me correct there is a bank of three under a cover on the offside front wing but i carnt remember which one it is but they are all the same
Dec 30, 2008 | 1982 Alfa Romeo Spider
Xbox has burnt electrical smell
my xbox power is 100v and i connected it to 200 v
waht shal i do
Apr 04, 2008 | Microsoft Xbox Console
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
