DVD going crazy
On my dual tv the DVD goes crazy. When I turn the DVD player on it does nothing. Just sits there and then the whole tv turns off after about fifteen seconds. Any suggestions?
  • 4,234 Answers
First a few informationsl points, then a question or two.
1) Upon startup, the unit will attempt to get to a "known state". This usually uinvolves miving the optics to a home position close to the center of the disc.
2) The optics will attempt to determine whether or not a disc is in the unit.
Questions:
1) Do you hear any activity inside the set at all?
2) Is there a standby light that blinks at all or just shuts off?
3) You should hear the high voltage kick in for the TV portion as well. Do you hear this?
We are trying to determine where in the startup process, the set is stopping. That will help to figure out which circuit is failing and causing the set to shutdown.
Please update this and we'll attempt to resolve this. Also, please supply the make and model as that will alow me to give you specifics.
Thanks,
Dan
Posted on May 19, 2008
    President:
  • 2,712 Answers
Not sure what the problem is..could be a problem with the relay or powerboard. Best bet is to get a repairman take a look at it. Dont try to open it yourself, as there are high voltages inside (even when powered off) that can kill...
Posted on May 18, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 7 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I have a Malata DVP 890. I pressed a button on the remote (it is in Chinese) and the crenn dissapeared. I can get sound from the DVD if I use the red/ whiit and yloow plug connections. Nothing with...
unplug the unit for about 20 minutes. This should allow the unit to go back to it's factory default settings.
Switch the TV to the HDMI input. Turn the TV off - hook the unit up with only the HDMI and turn on the TV.
If all goes well, the TV should signal the DVD player to turn on.
If not, wait about 10 minutes then manually turn on the DVD from the front panel (not the remote)
This will usually fix you right up.
Mar 08, 2011 | Televison & Video
I just bought a Samsung HT-C5800 Blu-Ray DVD player and connected it to my TV. (Which is also a Samsung) I am having trouble with my remote control. The remote for the DVD player will not work for the...
Make sure nothing is blocking the front of your DVD player. You need a clear line of sight between the lower right corner of the DVD player where the sensor is and your remote. If your DVD player is sitting high on a shelf or lower than you are when you are sitting in front of the TV, it may be at a bad angle to "see" the remote.
This will sound crazy, but it often works: While standing up, point your remote at the wall opposite your DVD player at about the same height, and see if it works! This is a sure sign that the angle between where you are using your remote and your DVD player needs to be adjusted.
FYI- this often works because bouncing the remote beam off of an opposite wall spreads it more than pointing toward it, and is a good way to test your remote.
Feb 24, 2011 | Televison & Video
I have a new lg tv and I can't get my dvd player to work? Please help! The dvd player is connected and turned on when I press the play button the green light turns on but It does not play on the tv nothing...
is it possible that you just need to adjust the TV to the proper channel? some DVD players default to ch3 others to ch4and if your using the av jacks make sure you haven't actually either plugged them into the input jack on the DVD player or with the new flat panel TV's you probably have a large number of input choices it is possible that you may have misplaced the inputs to ones that are close but are really meant for something else...
Dec 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Just purchased a Magnavox vcr/dvd player and cannot hook up to our cable box
You have a line coming in to the box for the cable and a line going out to the Tv. The line going out to the TV goes to line in on the dvd/vcr and the line out on the dvd/vcr to the TV.
Dec 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Toshiba 37WL66AS LCD TV troubleshooting color control Our Toshiba 37WL66AS LCD TV has an image color problem. Ever so often the screen goes reddish (especially skin tones). Turning the TV off for greater...
my toshiba tv.is around 6yrs. old...this morning when i tried to turn it on,..nothing...i have cable so i use a "box" & my cable company remote...i can turn on the box manually..the remote turns on my dvd player.{sony]...we had a blizzard start during the night..my cable company said they were having problems..i cannot turn on the tv manually..it does nothing at all...is there a safety feature that is causing the problem?..the model number is;27df46...serial number;BAB614020144A...PLEASE ADVISE...Fiona Duffy
Dec 05, 2009 | Toshiba Televison & Video
Can't get rid of subtitles
Often the subtitles are a function of the TV. Check the menus on the TV and turn them off there. Sometimes merely muting and un-muting the TV is all it takes. Other times, you have to go into the settings.
Aug 18, 2008 | Sony DVP-NS57P
Playing dvd
Make sure the video cable is going from the OUT of the dvd player (and make sure the color matches up), and make sure the progressive scan is turned off
www.philips.com/support for more details
Aug 15, 2008 | Philips Magnavox DVD/VCR Dual Player
Dual DVD VHS: DVD won't turn on
The Maganvox website has a warning about playing dual layer discs on this unit - it does not work and they don't have a fix for it yet. 1-800-605-8610 for more info
May 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Disc is not being read,not spinning
I had this same problem with my Apex AD-500W DVD Player. I decided since everyone said the player basically needed to be replaced it wouldn't hurt to go through the buttons on the remote just to try and figure it out......I DID!!!! I turned on my DVD Player, inserted a disc, turned on my tv and then hit the SYSTEM Button right below the power button until the screen said MULTI and the machine started working perfectly. There are 3 settings in that button, PAL which made my screen go crazy, NTSC ( i have no clue) and MULTI(this one made it work)! Hope it also works for all of you!!!
Apr 21, 2008 | Televison & Video
DVD player was working. Now, when any DVD is placed in, it just reads "loading" and nothing happens. Is the DVD player dead or is there hope?
Apr 12, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
