Question about Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher
Washer is making grinding noise after start. I found little plastic pieces in the filter in top washer drain. Cleaned it all out including the well which turns the rotating sprayer on. Less noise but it was not eliminated. Is it possible that the drain pump is making the noise? If so how do I get a repair manual to take the pump out and replace it?
  • zulfi573 Sep 16, 2010
    Hello Ginko,
    The appliance model is DD603 ZW USA, Serial No 88269 RSM 743676.
    The repair manual you emailed does not include that model. Is there much difference?
    Would you please email a service/repair manual that covers model DD603.
    I could not find list of parts and part numbers. Is that available?
    Thanks
    Zulfi573
  • Eric Perez Jun 24, 2012
    Knocking Sound immediately after start...Hard water caused my rotor to calcify or just fail....I learned this by removing the blue rotor (easy) and twisting it (holding large white flange) - comparing the rotating action to the other well-functioning rotor. If the vinegar bath does not fix it, I will probably by a couple of rotors . May have been caused by a mechanism fail in the rotation assembly. Eric, Valencia CA
  • 10,865 Answers
Hello. Contact the company's US office and request the repair manual Fisher & Paykel Appliances Inc.
5900 Skylab Road
CA
92647
Huntington Beach
USA
Phone: 1.888.936.7872
Posted on Sep 17, 2010
  • Ginko
    Ginko Sep 30, 2010
    Hi Manual posted was for DD605, as in title. I see your last request only now that the solution has been assigned, I had DD603 as well but this problem is closed. Well you have the alternative solution. Please call Fisher and Paykel, they will also be able to send you the part list.
    Alternatively ask here , that is free:http://applianceguru.com/forum1/12822.ht...
    A sincerely sorry Ginko.
  • Fisher and P... Master
  • 19,396 Answers
Hi.
The pump making noise is a common failure. Before replacing the pump undo pump hoses and ensure that there is no foreign object in there.
Here the full service manual in PDF format.
If the solution was helpful, please do not forget to accept the solution. Feedback is important for us.
Posted on Sep 16, 2010
My washer suddenly started making a grinding noise while spinning.
You did all you could do it sounds like somebody had something in a pocket an it fell out got between the drum of the washer an housing an is gonna make noise for a long time till you replace the washer sorry it happens all the time
Nov 16, 2015 | Washing Machines
Kenmore 70 series model 11020702990
the part is a little rubber/plastic bushing that has wore out it is on the shaft coming off of motor to the other unit to work washer u should be able to see this when washer tilted up and see the wore part and is mildly easy fix unless this is a all enclosed unit with engine
Sep 03, 2012 | Kenmore 22422 Top Load Washer
Samsung DMR78 dishwasher makes a grinding noise at the beginning of the wash cycle as well as the rinse cycle. Also comes up with the code 9E on occasion.
Check the brackets that hold the top rack for any broken plastic brackets. My dishwasher was making the same noise and after noticing the broken plastic pieces I pulled out the dishwasher put it on its side removed a white panel on the bottom that is attached with two screws, removed the drain line and inside there were two plastic tabs from the broken bracket. Once those were removed the grinding noise stopped. The bracket holding the drain hose can be removed with a pair of pliers.
Jan 01, 2011 | Samsung DMR78AHS Builtin Dishwasher
Drain pump problem and housing removal
Go to appliancepartspros.com or repairclinic.com. Enter your model number. Look thru parts until you find the pump. There you will find a how to video. Pretty easy repair/replace. Good luck.
Apr 28, 2017 | LG WM2688HWM TROMM SteamWasher
Roper washer not draining
okay you say coupler was broken, make sure coupler is on properly, and make sure your pump is clear of debri, sounds like you washed something heavy, make sure your pump is also clear
Apr 03, 2008 | Roper RAX7244KQ Top Load Washer
Error with 'Debris Filter' on Samsung WD-J1255 machine
remove pump and dismantled it,I don't think the rubber you found is off the machine,look for something caught in pump
Mar 21, 2008 | Washing Machines
LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Fisher and Paykel DD605HSS 23 in. Built-in Dishwasher Logo
112 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
