My boiler glow.worm 38 cxi keeps blowing the fuse in the control panel, not touched the wiring powering the boiler, any ideas? changed fuse lasted aprox 2 mins, we have had to drain system due to rebuild in house but wont stay on long enough to refill or restart had error codes F14 and F24? then filled system slightly and got F13.
3 Suggested Answers
  • 120 Answers
SOURCE: service manual for a glow worm 30cxi boiler
Follow this link
http://www.glow-worm.co.uk/stepone/data/downloads_sd/51/00/00/cxi-range.pdf
Cheers
Posted on Aug 13, 2010
Buffalo12980
  • 625 Answers
SOURCE: glow worm combi boiler
check the pilot line for an obstruction. check the millivolt generator that's supposed to keep the pilot valve open. check for a high limit control being bad.
Posted on Dec 27, 2007
Glow plug fues blowes
the glow plugs have a rail/wire that joins /links all of them that rail receives 12volts across it ,check that it is not touching against any metal earth surface ,if it seems to be fine disconnect the power wire to the rail and insulate wire .Then refit fuse and turn on key ,if the fuse blows you know that there is a short in the wiring going to the glow plugs ,if the fuse does not blow it is highly likely that one of the glow plugs has shorted and needs replacing
Jan 15, 2014 | Cars & Trucks
04 chevy colorado #21 fuse keeps blowing
your going to have to remove the inner door panel and liner to look for frayed wire(s) also may have to look at the wires running in the boot that runs between the door and frame.
Jun 02, 2013 | Chevrolet Cars & Trucks
Amana AMH95 Blown control fuse
Control fuses only blow with a 24 volt problem. Make sure that you replace it with a fuse NO LARGER than 5 amps.You could have a thermostat wire pinched or some wire touching the cabinet inside the unit, but it is a 24 volt problem.
Jan 22, 2013 | Amana GMH950453BX Gas Furnace
What keeps causing the ac cont fuse to keep blowing on 97 lumina? If i disconnect the power to the compressor and reconnect it the fuse will last about 10 minutes. If I put a fuse right back in after it...
There is a short somewhere in your ac system. You may be able to find it if you can take the time to go through it. I would start with the ac control panel. Unscrew it from the dash and see if any wires are burned and touching each other.
Aug 31, 2009 | 1993 Dodge Intrepid
My alpha cb24x combi boiler keeps blowing the main fuse,even when its not on,this can happen in 2mins or 2 days after i redo the fuse using 15 amp wire, why is this happening ?
a short circuit most likely on the pump or another winding, fan or gas valve. start with shutting off the power and pocketing the fuse untill ur done . dissconnect the pump supply and fit terminal blocks to make them safe. then turn the power on , but do not let the boiler run on either water or heating . let it sit for a spell and if the fuse does not blow simply replace the head of the pump, which is easier than replacing the complete pump. remember yuor not allowed to touch the gas train.
Apr 26, 2009 | Water Heaters
Glow worm 45 60 boiler
You have to have 12" clearance on all sides.
Apr 02, 2009 | Water Heaters
My 1997 F-350 powerstroke keeps blowing a 30 amp maxi fuse
I changed the glow plug controller selinoid haven't any problems since Thank You!
Mar 24, 2009 | 1997 Ford F350 Crew Cab
Glow worm combi boiler
Dec 14, 2007 | Desa International GWP20T GLOWARM Wall...
Heating & Cooling Logo
281 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
