The strip which the blade run along has briken at the end therefore the strip keeps coming out and has been cut . Can we please get a replacement? and what would the price be? Many thanks Barbara Hardwicke
  • 10865 Answers
SOURCE: I sharpened the blades at the end of last mowing
The problem you discribe is the classic broken blade spindle or quill. The tube that supports the bearings between the deck pulleys and the blades is almost certainly broken. Look under the deck [mower OFF] at the piece right above the blade that is malfunctioning and you will probably find a bad bearing or a chunk of the tube that holds the bearing/blade to be missing. That happens when the blade gets 'wacked'. The outer edge is cutting too high because the belt is pulling the shaft toward the center of the deck. The quills are fairly easy to replace. Get the model number off your tractor before you go to buy the part.
Posted on Apr 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: Installing a 10uf capacitor along a speaker wire, no sound
Way too low!!
Your cap should be up in the 200mFd range.
CLICK HERE for a calculator - since it in unclear whether you are using a component set as in the selected item - or a single speaker.
put your impendence in of the woofer, and the crossover frequency you are wanting to achieve.
Then use the first or second order cap. value.
Thanks for using fixya - a fixYa rating is appreciated for answering your FREE question.
Posted on May 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: motor on miter saw is runnig back wards
I would suggest going to Milwaukeetool.com and typing in your model number and pulling up a wiring schematic for this tool. If your switch and field are not as shown on this breakdown (its a good one) I would either take it to a repair center or change what is wrong one wire at a time. They also have a toll free number and would be more than willing to help with your problem. Let me know and have a good day. P.S. I would not run the blade backwards though.
Posted on Jun 22, 2009
supernova278
  • 1932 Answers
SOURCE: I have the Kenwood Major
You can get the blade from below webiste
http://www.4kenwood.co.uk/cgi-bin/product.pl?PID=603443&item=4503730§ion=347026&path=345550,346570,346951,347026
Thank You
Posted on Nov 11, 2010
  • 3074 Answers
SOURCE: The bolt that holds a cutting blade on is
if you take the pulley off, then the bolts that hold it to the deck it will drop through the deck, then may with a vice and a pipe wrench the you may be able to get off or replace the spindle. Hope this helps Tim
Posted on Mar 30, 2011
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
After taking my blades off to sharpen them, a strip of grass in center of cut path is left when I mow.
The blades are very carefully made so that they slightly overlap. This is why on some machines when you turn one way there will be a strip as described. If you ground the ends shorter, they will not overlap, and this is your problem. You should only sharpen the lower cutting side [NOT THE END] of the blade. Make sure that they are evenly ground back, not more near the outside as this will result in a curved cut with low centres and slight ridges in the middle of the blade paths. Also important to accurately balance them. Place nail in vise and put blade so the exact centre of the hole is on the nail, splined blades can be difficult. Maybe necessary to get ring of tube to fit inside spline. Grind off low end until they hang level.
Sep 27, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I am having problems with the usb cord staying in place when using the window mount. The cord keep coming off and I was wondering if anybody else had this same problem?
Yes, I have, and have the same unit, i solved it. Here is what you do, you put a small piece of Velcro on the unit next to the port( use scissors to cut to size) the about a inch or so, up the usp cord, you get that skinny 1/4 strip Velcro that you put around cord, and has a little kind of tail about 1 inch or so, that way when you plug in your usb to unit, then the Velcro strip on cord, you push the end on the Velcro end you put along side of the unit where usb plugs in and keeps it secure. This should do it and, if it does help you as it did me, please respond by some thumbs up and happy gps-ing. Thanks Mike
Jun 15, 2011 | Magellan Roadmate 5045 3065 3055 3045-LM...
The diamond insert in the hub of the blade keeps falling out as soon as I start a cut. What is wrong?
DO NOT USE SAW!!!
1. switch off saw, remove cord from socket (positive electrical insulation)
2. lift table for maximum cut and check size of the washer holding the blade,
3. you should have holding nut with collar, collar is about 1 1/4 (32mm) diameter, then blade (diamond is actually universal reducing bush in some blades) and lastly you should have internal washer, again, about 1 1/4" (32mm) diameter. if your collar are smaller, you need to replace blade as not suitable for your particular model, albeit I am rather suspicious that you have wrong collared nut and internal collar. Please check if both collars are exactly this same diameter. Please check if collars cover diamond cut-out.
4. if you see discreptancy between description in 3, purchase suitable blade (external diameter is 7 1/4" (184mm), as you did not supply what model of your saw, therefore most probably shank is 5/8" (16mm),
5. mount internal bush (collar), will go correctly only in one way.
6. mount blade (pay attention to cut direction, cutting surface should be clockwise if you look at mounting shaft.
7. mount external flared nut
8. check blade for slippage and wobbliness
9. connect power cord and switch on/off
10. check saw blade againg for slippage/wobbliness
11. make test cut if 10 was correct
12. use normally
Do not forget that this is not a toy, it will cut through wood, ocassional nail and your fingers.
Opearating saw crate flying debris, always wear googles or facemask, you have only two eyes and there is no spares.
Please leave note how you go with this advice.
Aug 18, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Blade wonders on straight cut
When doing any straight cut use a straight edged piece of something to run the jig saw along, using as a guide, this will usually keep it all straight, sometimes it can be a loose blade, or a bent shaft?
Mar 08, 2010 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Rear defrost stopped working. All contacts are on
The strips that are attached to the glass that run horizontally always suffer from the age old problem of corrosion. The best way to tell if it is these strips that is causing the problem is to hook up an ohm meter (x10 setting) and check for continuity. If this is good, the relay that feeds the defroster is probably bad or disconnected. This is located under the dash by the fuse box. Check to see if it clicks, and further check to see if you actually get 12v at the contacts back at the back glass. (12-50v setting). If you get 12v and the strips check infinite ohms, problem is, of course, the strips. Best fix is a new glass, but there are kits available that might be able to fix it (various results). Good luck.
Jan 08, 2010 | 2003 Chevrolet Impala
SAW BLADE STOP CUT MOTOR RUNS THEN STARTS CUTTING
It sound like a gear is stripped or the mechanism that drives the blade is broken. Please give me the exact model and tool catalog number and i will try and find a breakdown.
Aug 22, 2009 | Clarke Power Products Saws
I sharpened the blades at the end of last mowing season. The next cut was very uneven, so I checked to make sure that the blades were installed properly and re-leveled the deck. The last cut was even...
Apr 04, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Fridigaire washer that won't spin
Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Mar 11, 2009 | Frigidaire GLTF1240A Front Load Washer
k24674
jasbo
jasbo
