Question about Motorola RDU2080d Two Way Radio
Need manual for Motorola rdx series two way radio.
  • Motorola Master
  • 1,654 Answers
Here is a link to the user guide: http://www.astracomm.com/media/pdf/RDX_Display.pdf
Best regards.
Posted on Sep 16, 2010
What motorola radios are compatible with mu21cv, mu22cv and mu24cv
Any Uhf Motorola business radio can be programmed to match. None of the toy radios will ever work. (GMRS/FRS)
Easiest to self program will be the the XTN, also called CP100, and RD (RDU) and even older Spirit and SP10 are possible, but harder. RD's are really hard without the programming cable, available from a dealer.
Sep 08, 2015 | Motorola Radio Communications
Need manual
Here is a link to the RDX series manual for RDU2080d:
www DOT motorolasolutions DOT com/web/Business/Products/Two-way%20Radios/Mobile%20Radios/_Documents/RDX_Series_Two-way_Radios_User_Guide_RDU2080d-RDV2080d-RDU4160d DOT pdf
Aug 25, 2013 | Motorola RDV2080d Two Way Radio
Need the DPL or CODE for Motorola RDV2020
The RDV2020 is programmable to many different PL and/or DPL codes. Here is a link to the manual: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
You can read about reprogramming codes pages 36-44. Or simply reading out the code on page 40.
Best regards.
Aug 13, 2011 | Motorola Mobility RDV2020 RDX Series On...
I have a Motorola RDV2020, when I try to write to the radio it says the memory is corrupted and to perform a factory reset. I tried the device reset with the software connection to no avail. Is there an...
1) You can try the manual reset by pressing the PTT, SB1 and SB2 simultaneously for 3 seconds while turning the radio on. Then reconnect the radio to your computer and try reading the radio. If you are able to read the radio, you can then reprogram the radio.
2) If the above does not work, try cloning a known good codeplug (saved archive of another good unit) into the radio without reading it first.
3) If none of the above work, your radio will need to be seen by Motorola or an authorized dealer with knowledge of the RDX series.
Best regards.
Mar 22, 2011 | Motorola Mobility RDV2020 RDX Series On...
I have four out of commission radios and need to get them fixed, I'm thinking it might be a battery problem. Anyone know where I can send them in to get them fixed.
Replacement battery packs are available for the RDU2020. You might want to try replacing the battery before sending them in for repair. Or if you think they are truly in need of repair you can contact your local Motorola dealer or the Radio Repair Center, where the RDX series of radio is currently repaired at a flat rate of $85.
Best regards.
Dec 23, 2010 | Motorola RDU2020 Two Way Radio
How do i get my motorola radius sp50+ to communicate with my motorola rdx radios
The radio must be reprogrammed by an authorized dealer to match the frequencies in your RDX radios.
Oct 02, 2009 | Radio Communications
No user manual for the RDV2080d
Here is a link to the programming software http://www.radioserviceincorporated.com/files/1935423/uploaded/RDX_Series_CPS_R01-00.zip
And here is a link to the user guide http://www.astracomm.com/media/pdf/RDX_Display.pdf
The RDV2080 VHF with display would be compatible with the XTN series radios which have a model name starting with XV, as in VHF. Typically the RDV2080 ships on the default frequencies found in the XV2600. So if you have not changed your XTN frequencies/PL code they may match out of the box.
On a sidenote: The Motorola CP110 VHF is also compatible. It is an industrial version of the RDX radio. It has a few more channel capability and a replaceable antenna. It looks just like the RDX models, and it is the replacement radio for the CP100 and/or XTN.
All of the above mentioned models are repairable.
Jul 20, 2009 | Motorola RDV2080d Two Way Radio
Motorola RDU2080d  Two Way Radio Logo
85 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
