Question about DeLonghi Microwave Ovens
Coffee is not hot. - DeLonghi Microwave Ovens
  • DeLonghi Master
  • 17,130 Answers
Possible that the selected time or power was insuffcient. Use a longer time with the same power rating to steam the coffee.
However if the coffee is not heating I am afraid we need to check on the Magnetron, capacitors or transfomer.Can it be also low mains voltage?
Posted on Sep 16, 2010
How do I make coffee with this
make up a normal cup of coffee without hot water
coffee in the microwavable cup+ water+ milk if needed
stir well
zap on high for 1.30 to two minutes
May 29, 2016 | Microwave Ovens
Stoped heating smels hot. Should I replace the magnatron or high voltage transformer or both
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 01, 2011 | Magic Chef MCD1311ST Microwave Oven
My Kuerig coffee maker putters out the coffee, there is no fluid stream of coffee like before. The coffee maker makes the sound like coffee will come out but then there is nothing but drops.
try runing a descaler throgh it first,see if that solves the problem, after a lot of use scale builds up in most applianced using hot water
Jul 29, 2011 | Microwave Ovens
My 12 cup coffee maker does not keep the coffee hot after it has been made - whats wrong with it......
The heating element is open on the warming plate, cheaper to replace the coffee maker for a new one.
Feb 27, 2011 | Microwave Ovens
Our Magimix 11400 (less than 2 years old) heats normally, the vapour nozzle fonctions too, but our problem : when the coffee selection switch is put on the motors starts up, seems to fonction properly but...
Hello Pat, You have a common occurring problem. Your tubing in clotted. The least expensive solution is to use regular vinegar instead of water for several cycles, no coffee grounds. The clot will dissolve and water flow will return to normal. Cycle just water until no taste or smell of vinegar is present. Have some HOT COFFEE.
Oct 12, 2010 | Microwave Ovens
Heating the cup more than coffee
make sure the stirrer motor located under the outer cover that distributes the microwaves is turning otherwise you will get hot and cold spots in the oven cavity
Apr 30, 2010 | GE JVM1870 Microwave Oven
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
CUP HANDLES GET TO HOT WHEN I WARM COFFEE.
It is your cup. The handle density or moisture content of the handle is causing the mwave to heat it. The rest of the cup contains a liquid (coffee?) that is absorbing any heat generated in the body of the cup. Use a different cup!
Nov 30, 2008 | Maytag Microwave Ovens
Microwave Ovens Logo
43 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
