Question about Health & Beauty
My phone sim 2 not working - Health & Beauty
  • 17,130 Answers
The hardware or the software is faulty. So firstt of all interchange the SIM and chek to confirm if the other SIM is working. Clean the SIM contacts , reset phone and try. if not get this checked with the dealer there is no much you can do,
Posted on Sep 16, 2010
U8661 dual sim sim 2 workin' sim 1 doesn't working
Jan 30, 2013 | Huawei u8661 dual sim
My new sony ericsson c 510 phone is brand new.i am used it 2 month.last week some times display inactive sim and not work phone.some time work calling the phone cut the line beep tone.display inactive sim...
Inactive sim is usually related to your SIM Card, you should try reinserting your SIM card again, to see if it works, or simply insert your current SIM card into another phone to check if there is any service. should both failed. It should be your SIM card problem, you can contact your service provider or carrier to have a replacement SIM.
Mar 12, 2011 | Sony Ericsson Cell Phones
I put my samsung on it dosent work couse my sim is not registed
1. If it is a new sim card wait till the service provider registers the sim.
2. If it was already working previously insert another known working sim card. If same message comes clean the contact points on the cell phone.
3. If above 2 dont work your phone IC is corrupted and you need expert help.
Try the above. I hope this helps
Mar 10, 2011 | Samsung Cell Phones
When I turn the phone on it says SIM Crash can someone help me?
hello.
For phone to have said sim crash, the problem can be view from two ways
1.From the Sim it self.
2.And from the phone.
solution1.
remove your sim from the phone and insert it to another phone if your work it means that the problem is from the phone and if it does not work it means that the sim is bad
2. From the phone
You need to test your phone with another sim to determine were the problem is from,if the problem remain what you need to do is to change the sim carrier of your phone so that your sim can work together with your phone again.
Good luck.
Mar 07, 2010 | Cell Phones
IT SAY SIM LOCK AND ASKING THE CODE
This may not work on all Samsung phones!
THIS IS THE TEMP UNLOCK CODE FOR A SAMSUNG PHONE
Do this at your own risk:
Instructions
Press *#06# and write down your IMEI
Unlock Codes
Code 1: *2767*688 then your IMEI and then press #
For example *2767*688352708000828246# (Everything before the / for C225)
Code 2: *0141#
Code 3: 00000000 (8 zero's)
Entering the Codes
1. Switch your phone off. Remove the original SIM card 2. Insert another SIM card from an alternative network. Power up your phone. You should now see the "Wrong Card" message. 3. Type Code 1 into your phone, if this is entered correctly your
phone screen should now turn black and reboot itself. (C225 doesn't go
black but does reboot) 4. After the phone reboots the SIM card will be recognized and your
SIM will work. Be patient while your phone reboots and DO NOT press
any keys. At this point the phone is "Temporarily" unlocked.
5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
This should give you a message saying the phone is "Personalized". 6. Power off the phone and insert the original SIM, then power up. 7. At the SIM code prompt, it will ask you to enter a password. At
this stage enter Code 3. 8. After entering hit "OK" and your phone should complete initialization.
[/b]Instructions[/b]
Unlock Codes
Code 2: *0141#
Entering the Codes
any keys. At this point the phone is "Temporarily" unlocked. 5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
Your phone is now Permanently unlocked.
Another easy way is you put in a foreign sim put in the code *2767*2878# much easier and works just the same.
*2767*688 <your IMEI number>
Jan 09, 2010 | Samsung SGH-X820 Phone
I have a unlocked sciphone i9+++ and it always says no service, how do i fix this?
First, do you have a sim card in it that is activated and working with a GSM phone provider?
Second, assuming you do ( i took my old sim out of my previous working phone), does the phone see the sim? can you set up a sim password or change settings? If you can save to the sim or change settings, likely the sim is fine and the problem is with your phone.
I have 2 of these phones, one works great, the other... when I put the same sim in that works in #1, #2 phone will give me the 'no service'.
I have narrowed this down to being an anteana/receiver issue with the phone... I am in the process of getting it replaced.
Thanks
Nov 01, 2009 | Dual Electronics CECT P168 Cellular Phone
My sim card doesnt work in my sciphone i68+
I see that this had been a while. The reason that your Sim cad doesn't work could be various: 1. Make sure that your phone is quad band, if it's a tri band then make sure that ATT works in 1900mhz. If it works only in 850 and your i68+ is a tri band, (which is not suppose to) then it will never work. As far as I know all i68+ original are quad band, some fakes i68+ are sold as quad band but are actually tri-band. 2. If you ATT sim card is a 3g card, it won't work either. These phones are not yet equip to work with 3g. I hope this clear up at least a little of your doubt with the Sciphone.
Sep 01, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
SIM 2 SLOT NOT WORKING
This phone does not work in the UK anymore as stated on any legit ebay site for the Sci Phone.
Aug 19, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
My phone is not registering when you insert the sim card?
Aug 05, 2009 | Nokia N70 Cellular Phone
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
