Question about Whirlpool Washing Machines
We have a whirlpool super capacity plus washer commercial quality 9245H, does this machine have a lint filter and if so how do we clean it?
    President:
  • 1,554 Answers
You did not state the complete and exact model number but based on the model number given, I assume the machine is a top loader. The closest model number I found is 6LSC9245HQO and this machine has a Magic Clean lint filter located at the bottom of the basket. Wash and rinse water flow over the filter, separating the lint from the water. The lint then spins out of the machine during the spin cycle.
The only way to access and clean the lint filter is by taking out the basket. This requires the removal of the agitator then the basket but you will need a special tool called spanner nut wrench to remove spanner nut holding the basket to the drive block.
Please indicate the exact model number of the machine for more specific advice or if you need further assistance. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. But accepting the solution will not stop you from communicating with the expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 16, 2010
I have a Whirlpool Super Capacity Plus washer (Commercial Quality) model 6LSC9245HQ0 and I am getting a lot of lint all over my clothes. Is there a lint filter? If so where is it and how do I clean...
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Apr 10, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How to remove aggitator from center of machine to clean inside of it, there seems to be little bits of whatever coming from there its a whirlpool super capacity plus 8255e commercial quality
Pry the top lid off the agitator.
Remove the plastic shield inside.
Use a 7/16 socket and extension to remove the bolt.
Pull the agitator off the shaft.
Mar 04, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have resently purchased a second hand super capacity machine, not yet run it. The softner receptor is very dirty and I was wondering how to clean it out. I have taken the top bit off but am unable to...
You can use vinegar to clean the machine take 100ml of vinegar and two buckets of hot water till the plastic tolerance then start the normal program the hole machine inner unit will be cleaned you can use the same process two months once the cloth cleaning quality will be good
May 17, 2010 | Whirlpool 3.2 Cu. Ft. Super Capacity Plus...
Whirlpool super capacity commercial washing machine
Sounde like a bad lid switch . With no model number , can't help you further .
Sep 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Whirlpool 8255e makes ''whirry'' sound when pumping - not spinning
there is probobly something small jammed into the pump
common for that sound would be a underwire for a bra.
is it still draining ok?
May 26, 2009 | Whirlpool Washing Machines
Can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Nov 01, 2008 | Washing Machines
Cannot find the model number on my Whirlpool washing machine. It is a top loading machine, with such features as: 4 Load size, 4 Tempature settings, 8 cycles, 4 speed combinations, commercial quality....
If this was a scratch and dent model, model number may have been removed prior to sale. If not, you should find it on the back edge of the washer at the very top as you look over the back of the machine. If you can't find a model number, bring the part(s) you need to a servicer. They may be common parts or there may be some identifying numbers on the parts themselves. Good luck.
Sep 01, 2008 | Whirlpool Washing Machines
Filter? Is there a filter I should be cleaning out periodically?
There is no filter to clean in your machine.....any lint or other build up is designed to go out with the drain water...
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
229 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
