Question about HP PROCURVE SWITCH 2510-24 24PORT 10/100 2PORT DUAL KVM Switch
HOW TO ACCESS THE J9077A ProCurve Switch 1400-24G FROM LAN & WHAT IS THE DEFAULT IP ADDRESS .
    Sergeant:
  • 378 Answers
This switch is not a manageable switch. NO IP address.
Posted on Apr 25, 2011
What is the default IP of HP ProCurve 2510-48 ?
There is no IP address when the switch ships from the factory. It is set by the user and/or the network by DHCP. If you do not know what the IP address was set to, then you'll need to return the switch ti it's factory default configuration. There should be information in the manual for the switch about the default config.
Jul 02, 2014 | HP ProCurve Computers & Internet
2626 default ip procurve
HP 2626 do not have a default IP address, you have to set the IP address on an enterprise class business switch. You can find the manual for your switch at http://www.hp.com
Dec 23, 2013 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
What is the default ip address for the procurve 2124
Procurve switches do not have a default IP address. you must put an IP address on the switch. You can find a manual for your switch at http://www.hp.com
Nov 18, 2013 | HP ProCurve 2124 (J4868A#ABA) 24x10/100...
Default ip procurve 2510 48
there is no default ip address on a procurve switch. you have to put an IP address on the switch. You can find a manual for your switch at http://www.hp.com
Oct 12, 2013 | HP procurve switch 2510-48
J9400b defult ip adress
There should be no default IP address on a 2626 switch. HP Procurve switches are setup by default to get an IP address by DHCP. To execute the factory default reset on the switch, perform these steps:
  1. Using pointed objects, simultaneously press both the Reset and Clear buttons on the front of the switch.
  2. Continue to press the Clear button while releasing the Reset button.
  3. When the Self Test LED begins to blink, release the Clear button. The switch will then complete its self test and begin operating with its configuration restored to the factory default settings.
Be aware, using these instructions will wipe out any configuration you have on the switch
Good Luck
Jan 21, 2012 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is 192.168.2.10 and the subnet mask is 255.255.255.0"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
AFO
Dec 31, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Jan 31, 2008 | Sony Playstation 3 (PS3) Console
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
HP PROCURVE SWITCH 2510-24 24PORT 10/100 2PORT DUAL  KVM Switch Logo
1,304 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
