Question about Indesit W 123 Front Load Washer
Top loading hoover premier 710 model
Water not draining. have checked hoses under machine and there not blocked.thinking need to take inside of machine out.blockage must be under that.
    Brigadier General:
  • 6,966 Answers
If you have checked everything else, then it may be the drain pump or the "filter/catch". There is no real filter but rather is a part of the drain system. Normally it is at the very bottom of the machine. You need to remove the lower front panel. There would be 3 clips that holds it in place. Once the inside is exposed, there would be a black circular cover at the right hand side. Unscrew it out and clean the inside. It would normally be filled with water and some other "stuff" so pls have cleaning materials handy and/or anything to absorb the spilling water. You can now check the pump, the impeller and verify that indeed there are no clogs/blockage.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 24, 2008
  • THEUNIS Mar 31, 2013
    how do i take out the drum of the hoover top load washing machine.plaese reply to theunis@onsite-machining.co.za.
I need the lid for hoover premier 710 4 kg.washing machine. model A6578, serial no. 091383
only from hoover agent spares , machines at the dump or washing machine repair shops who may have some as spares
Mar 28, 2017 | Hoover Washing Machines
Hoover premier 710 washing machine out of balance
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 24, 2008 | Washing Machines
Premier 300 Not spinning
Check if the drain hose is blocked. Check the wires aren't loose on the drain pump. If all that's ok you will need to replace the drain pump.
Jul 08, 2013 | Miele Novotronic Premier 500 Front Load...
Hello, My dishwasher isn't draining the water away, it is approx 13 years old but not used to much in that time; Do you think I should buy a new one or get it fixed: it could be only a small problem: ...
On the whole dishwashers are simple devices.
A controller tells a pump what to do - push water around the machine or push water into the drain.
Miele machines have a very good record for lasting over 20 years.
If you are a "handy person" you could try checking the hose to the drain is clear - blocked hose won't drain.
Have you checked the filter system inside the machine - at the bottom of the d/washer under the bottom spinning arm? If this is blocked - no drain - so clean it well.
If little checks like this are all OK well its up to you - repairs could cost £60 - £80 a new Miele would be nearer £400.
Try to get it fixed its kinder to the planet - and your pocket.
Good Luck.
Mar 25, 2011 | Miele Premier-Plus Built-in Dishwasher
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Hoover Premier 706 (model A6950) washing machine.When filling water wont shut off.Turn power off water shuts off.If I remove hose from side of bowl and gently blow into it water shuts off.Machine is old...
Inserted flexible piece of thin wire into hose connectioin on outside of bowl and vigoursly wriggled it around - replaced hose and bingo water fills and shuts off and machine operates correctly. Seems like the hose connection was blocked, not a very scientific repair method but seems to have worked. Thanks.
Aug 14, 2008 | Hoover Washing Machines
Hoover Premier 710 - always fills to capacity (can't adjust water level).
my one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Apr 30, 2008 | Hoover HTC243 Top Load Washer
Water not draining during cycle
Did you check the lid switch?? Is it spinning???
Oct 05, 2007 | Washing Machines
Hoover wdm120
more than likely that yor pump hasnt let all the water out try getting your outlet hose from under the sink and place into a bucket low to the ground if water comes out than your door will open after a short while if water does come out than make sure your pump or drain hose is not slightly blocked if not then your pump is on its way out also if water doesnt come out of drain hose than take it off at the pump if it comes out then,then your hose is blocked m8
Aug 20, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Indesit W 123 Front Load Washer Logo
144 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
