Question about Dell 966 All-In-One InkJet Printer
On a Dell Photo 966 I am getting a "Printer Carrier Stall".... "Check inside the printer for obstructions then pres [tick]" I have just replaced both ink cartridges There are no obstructions. I have powered off the printer and tried again.... still same message. How can I overide this error messsage?
  • 1003 Answers
SOURCE: error 1200, printer carrier stall
check printer belt for missing teeth if none are missing lubricate carrier bar(big siler bar that ink cartrides trvel along) with 3in 1 oil with power off then back on to retry
Posted on Jan 07, 2008
SOURCE: changing ink cartridge in dell photo 966
It's probably located under the scanning bed.
Look for another section break below the scanning bed.
Lift it up. The print cartridges should be inside.
Posted on May 01, 2008
damanpreet_c
  • 69 Answers
SOURCE: carrier stall.
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
SOURCE: printer carrier stall
I am getting a "Printer Carrier Stall" message and "Check printer for obstruction" message. what can I do to fix it?
Posted on Nov 23, 2008
pineworks
  • 4041 Answers
SOURCE: my printer (dell Photo AIO printer 966) keeps
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 20, 2010
My printer has worked with many computers. But my HP Probook 64 won't drive it. Can you help me find a driver for this printer, mfd in 2007? Thank you / John
PDF]Dell Photo All-in-One 966
www.dell.com/downloads/emea/products/printer/966_en.pdf
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
Dell Photo All-in-One Printer 966, v.G16-EN-x64, A02 ' Dell ...
www.dell.com/support/home/us/.../Drivers/DriversDetails?driverId...
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
966 Personal All-in-One Printer Driver Downloads, Set ... - Dell
www.dell.com/support/Article/us/en/19/266187/EN
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Dell 966 All in One Color Printer Scanner Fax Copier
Dec 30, 2015 | Dell Photo 966 All In One Print Copy Fax
You may have had a foriegn object fall inside the printer such as a pen or paper clip.You may also have a broken sensor which enables the carraige to move to the centre when the lid is open. You can try and carefully move the carraige over manually when the printer is turned off to see if there is something blocking its path. If the sensor is broken you can replace the cartridges by moving the carraige over when turned off.
May 28, 2010 | Dell 922 All-In-One InkJet Printer
Lexmark x9350 printer problem
this is the result of a lose belt or dislodged spring, tightening the belt.
There is not much you can do, you can attempt to open the printer up and tighten the belt, however, it would be easier to buy a new printer.
Jul 21, 2009 | Lexmark X9350 All-In-One InkJet Printer
My dell photo 966 printer has a broken drive belt tensioner pulley. is there a disassembly guide and a parts diagram available?
my dell photo 966 printer has a broken drive belt tensioner pulley. is there a disassembly guide and a parts diagram available?
Jun 20, 2009 | Dell 966 All-In-One InkJet Printer
After adding ink cartridge printer stopped working
Parts for any ink jet printer are rare due to the low price of the machines. Technicians rarely repair them for the same reason. Who would want pay a technician $75.00 to repair a $100.00 printer? Consequently, parts generally not available beyond a few major sub-assemblies.
Feb 28, 2009 | Dell 966 All-In-One InkJet Printer
Printer carrier stall
Oct 03, 2008 | Dell 966 All-In-One InkJet Printer
Changing ink cartridge in dell photo 966
Mar 25, 2008 | Dell 966 All-In-One InkJet Printer
Dell 966 All in one printer
make sure sticker off ink as u put it in go download new drivers from dell.com for it they have big updates to fix that
Feb 21, 2008 | Dell 966 All-In-One InkJet Printer
Error 1200, printer carrier stall
Jan 06, 2008 | Dell 922 All-In-One InkJet Printer
Dell 966 All-In-One InkJet Printer Logo
120 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
