Question about Dell Latitude D505 Notebook
When i power up my dell latitude d505 i get the 3 lights next to the power switch then it turns off any ideas how i can fix this
  • Dell Master
  • 27,725 Answers
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Posted on Sep 16, 2010
Dell Latitude e5400, how do i turn off WIFI
Anonymous,
The WIFI switch on the Latitude E5400 is located on the front edge of the system to the left. You can move it to the right or left to turn on or off.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 16, 2015 | Dell LATITUDE Computers & Internet
My Dell D505 Latitude will not power up. The 3 green lights flash for less than a second and then it switches off. It was working fine until a few days ago. Any ideas of how to fix this as all my work is...
Sounds like ether a blown power supply. That happens when the laptop battery has alittle juice left.
Try to take out the battery from the bottom and plug the laptop in the wall. If the laptop powers up you battery needs to be replaced. If it doesn't power up, you need to replace the power supply.
Good Luck,
jsgrepair@co.nr
Aug 23, 2011 | Dell Latitude D505 Notebook
Dell Latitude L100 monitor not coming on
For the external monitor when you have it plugged in do you press fn f4 depending to switch from the lcd to the external monitor?
May 20, 2010 | Dell Latitude 100L Notebook
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Dell latitude D520 will not start up
The board not holding power,
this can be first chk the RAM press it tight.
the next is chk smps output.
Aug 17, 2009 | Dell Latitude D800 Notebook
The laptop won't turn on
Hi..
This seems issue with the power supply.
If the computer is in warrenty call dell.
Thanks
Smith
Aug 15, 2009 | Dell Latitude D530 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
Dell latitude d600 doesn't turn on
The test Dell advises to narrow down this issue is to remove the battery, hard drive, ram, and optical drive.  Next plug in the a/c power cord and you should get some LED's coming on. If not it points to the motherboard.
Aug 15, 2008 | Dell Latitude D600 Notebook
remove the battery from the system and try to power on the System with the AC adapter connected. its only to check whether the system is receiving the power .
Also press the Fn key holding it down press the power button and release both the buttons , look for the LED codes and do let me know abt it
Apr 21, 2008 | Dell Latitude D600 Notebook
Dell Latitude D505 Notebook Logo
135 people viewed this question
Alun Cox
