Question about Canon ImageRunner 3025 Black and White Copier
How do I programme the printer to stop printing when Tray 1 runs out of paper? I dont want it to continue printing from Tray 2
  • Canon Expert
  • 1,326 Answers
The answer is in the user manual. It is under additional funcation. Basicly you need to turn the paper tray off for printting. Or you can change the paper tray size. I'd type it out, but I have other things to do.
Posted on Sep 16, 2010
  • bronwynd427 Sep 17, 2010
    Thanks very much. Appreciate your reply.
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
HP 4100dtn Tray 2 picks the paper NON-STOP?
Step 1:Check with another cartridge
Step 2:Switch off the printer take out tray 2 casette, swich on the machine check while intializing the printer tray 2 pick up roller rotating?.. If its rotating check solnoid which is located right side under the main moto assembly, clean the solnoid as shown in the anap shot..fix it back.
Step 3:Open right ,left & top covers.., close cartridge access door check is it driving the laser scanner shutter?, if not check the sccess door knotch broken/bend.
Nov 20, 2011 | HP LaserJet 4100dtn Printer
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
I have a T620 that won't print from the trays because it continues to show ''Load MP tray'' on the display. When I drop down the tray and load the multi-purpose feeder, it will print what's in the queue....
Turns out that the paper tray was damaged - the tray was unable to determine the correct paper size, despite fooling with the green paper stop. I had to compare it with a known-good tray to see the problem.
Apr 28, 2009 | Lexmark Optra T620 Laser Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Only wants to print out of tray 1
paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
Nov 30, 2007 | HP LaserJet 4350 Printer
Canon ImageRunner 3025 Black and White Copier Logo
old marine
old marine
