Question about LG W1934S-BN 19" Monitor
When I turn it on it runs for about ten minutes. Off and on again it runs for maybe 5, then 3, then 2. What should I look for?
  • 23 Answers
Sounds like power supply or the cable may be bad. Try another monitor on same cable or same monitor on different computer with same or different cable exchanging components until problem stops. It may be the power supply to your computer is getting bad and cannot support the power requirements you need. OR, it may be that the monitor is starting to need internal component, like relays of power supplies for itself. Try the other stuff first.
Hope this helps.
Brock
Posted on Sep 16, 2010
My Merc Vito van cuts off after 5 minutes from starting it in the morning and will start after 10 seconds and will not cut off again unless I am on the motorway.
If it's not broke, don't fix it. I know of some companies that it's set in the computer to shut off if hasn't been moved in 5 minutes or so. But if it doesn't cause you any personal/physical discomfort, let it be.
Sep 25, 2014 | Cars & Trucks
No start after removing ignition switch and lock cylinder.
These vehicles have a built in antitheft system. When switching the ignition you interrupt this system. You will need to do a system relearn after the new ignition is installed. It will not start until the new ignition is installed and relearned. Step one. Put key in ignition, turn forward 2 clicks until right before it should start. Keep like that for ten minutes, NO LESS. Step two. After the ten minutes, turn key back to off position for 5 seconds. You need to do steps 1 & 2 a total of three times in a row without trying to start the car in between. The whole process should take roughly 30 minutes. After the last time waiting 5 seconds in off position, turn key forward and attempt to start the vehicle. Remember no less than ten minutes when forward, maybe do ten minutes and 15 seconds to be sure, some people even do 11 minutes.
Oct 28, 2011 | 2000 Buick Regal
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
hello
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
Sep 12, 2011 | Heating & Cooling
Replaced ignition lock cylinder and new key has no chip so it will turn over but now wont start. what to do?
CHARGE BATTERY / TURN KEY TO RUN POSITION FOR TEN MINUTES
SECURITY LIGHT SHOULD GO OUT / TURN KEY OFF FOR 3-5 SECONDS
TURN BACK TO RUN FOR TEN MINUTES / REPETE / USALLY TAKES
3 TEN MINUTE CYCLES / THAN TURN OFF / TURN ON SECURITY LIGHT
SHOULD GO OUT AND ENGINE START AND RUN
Dec 08, 2010 | 1996 Oldsmobile Cutlass Supreme Coupe
My car anti-theft seems to have kicked in and I can't get it to start. What do I do next?
hi, you can perform the reset with just your key and a battery charger to see if this will allow for restart. what you do is, hook up a battery charger to start with, low amperage setting like 15 amp, or maybe 2 amp, and leave it on the battery, you will be leaving the key on for up to an hour and the battery must not die during this time. turn the key on and try to start once for about 1-2 seconds, then let go and let key rest in run position for fifteen minutes at minimum. then turn off the key, wait ten seconds, and turn on again to run position only, leave on for another fifiteen minutes, then again, turn off for ten seconds, turn back on to run position for fifteen minutes. after this time, turn the key off, wait ten seconds, and try to start the car. if it starts, check to see if the check engine light is illuminated, or the security light is on, if one or the other is on, take to a shop and have codes checked and diagnosed, if no lights on, you should be able to drive on. if the vehicle does not start after three reset key cycles, try the process one more time. it may have been interupted somehow. if you try twice and still no start, you have to have diagnosed further, maybe in the key, maybe in the lock cylinder, maybe in the theft module.
Jun 30, 2010 | 2000 Buick Regal
My car wont start
sounds like security shut down which will start run for second then shut down after several time the security will shut down completely.......you can try what is called the relearn proceedure..this is what you dealer will do...might have to put battery charger on car first... then put key in ignition and turn to the run position do not crank leave it in the on position for ten minutes...... then turn key to the off position then back to the run position again for another ten minutes.....for the last time turn key off then back to run for the last ten minute cycle.... after the final ten minutes is up turn key to off position then attempt to start... let me know
Aug 31, 2009 | 1997 Chevrolet Cavalier
New ignition switch now car security system locked
ok here you go
make sure the battery is fully charged befor starting
turn ignition to run
attempt to start once then release the key in the run position
let vehicle sit with the key on for ten minutes
the security light should turn off
turn igniton switch off
wait 5 seconds
turn key to run position
let vehicle sit for 10 minutes
turn key off
wait 5 seconds
let vehicle sit for ten minutes
turn key off
wait more than 6 seconds
and start engine
Jun 14, 2009 | 2001 Chevrolet Monte Carlo
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
LG W1934S-BN 19" Monitor Logo
75 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
