Question about Trekstor DataStation Maxi x.u 320GB External (68143) 320 GB USB 2.0 Hard Drive
My external hard drive fell on the floor and now will not work how can i retrieve all the information on it
  • 6,831 Answers
Hello
Best is to take it to data recovery experts , but here is some info to try.
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Hitachi terrabyte beeping
I'm sorry to tell you this but unfortunately the fall killed it...
Jun 27, 2012 | Hitachi 1TB External USB 2.0 Hard Drive
My external hard drive fell off my bed onto the floor. Now it is no longer recognized by my computer. How can I retrieve the data that is currently on the hard drive.
Well this could be a tough one.
It seems likely that how much experience you have working with hardware as well as how willing you are to work with computer hardware my be a big factor.
Anyway. At this point does the external drive show ANY signs of life? Does it's led come on?
Does the drive seem to come to life? In other words. Can you heard the drive spin up (or spin in general for that matter)?
Also does the drive make any loud clicking sounds? Does the drive make any sounds that it was not making before it fell off the bed and on to the floor? Or is it failing to make any sounds that it always made before it fell off the bed?
Here are a few suggestions:
First consider carefully how valuable the data you wish to retrieve really is to you as opposed to how valuable the drive itself may be to you. For example, is this drive still under warranty?
If you open up the box it will void the warranty. If it is still under warranty they will probably replace it. So this is a serious consideration.
If the drive is no longer under warranty then it is not an issue.
If your drive shows NO signs of life then it is not getting power for some reason. This could be anything from a broken or disconnected wire inside the box to a broken interface printed circuit board.
If the led lights up but the hard drive does not spin up then this could also be anything from a broken or disconnected cable inside the box to a broken interface printed circuit board. It could also be that the drive has suffered catastrophic damage. If it is the later your data is history.
If the drive is making any loud sounds it never made before it is also highly likely that your data is history.
You can open the box your self and check for problems like disconnected or broken cables. Which should be easy to fix.
In any event good luck...
Jun 12, 2011 | Western Digital WD My Book Essential 1TB,...
Question re: Avolusion HDDGear Pro 500GB 16MB Cache 7200RPM USB 2.0 External Hard Drive: it fell off my desk onto a carpeted floor and now will not allow me to access my data on it. It makes a noise as if...
The bad News, when it fell it most likely knocked the heads or disk out of alignment or broke something inside. Good News - It may still be possible to recover the data on it but that will have to be done by a data recovery specialist company that can take the drive apart and read the Disk plates individually to reconstruct it. Bad News -That process will most likely cost more than the computer did as it is a very specialized field and requires very special conditions.
May 22, 2011 | Computers & Internet
Clicking noise
The clicking comes fro damage done to the read/write head hitting either the swing stop or the heads are out of alignment and clicking the edge pf the platters. The drive is mechanically damaged and cannot be serviced with extensive cost. If you need the data, you will have to get the drive to a data retrieval company.
May 13, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
External hard drive fell on floor. Now will not
I would send it back to seagate but don't tell them it hit the floor
Jan 09, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Files won't open on external hard drive after it fell 18 inches
ooo I have the same prob but mine.. the computer just doesnt recognise the external drive at all well if u find the solution plzz helpp...thnxx i hav evrythin on itt nd i need themm...
Jan 02, 2009 | Western Digital 500GB My Book World...
External USB drive making clicking noise - Windows does not recognize it!
The drive is damadged bad. youll have to go to a data recovery centre, but that can cost $700+ if you really want your data back.
Sep 19, 2008 | Western Digital (WD1000VE) 100 GB Hard...
LaCie Mobile 500gb not working
Just buy new external ( HDD ini is fine) just change the external for both off you
Dec 28, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Trekstor DataStation Maxi x.u 320GB External (68143) 320 GB USB 2.0 Hard Drive Logo
129 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
ray gallant
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
