Question about Microwave Ovens
Hi, I have a Simpson Nova (Thermaflow) 528 wall oven and I need a replacement oven light assembly clips and glass bulb cover. Where can I get it?
  • 27 Answers
SOURCE: Siemens HF87950 Internal Bulb replacement
Move unit forward out from enclosure about 20cm....the light is covered by a small panel on top of the casing.(uses torx T20 screws) Remove lid and replace bulb!
Posted on Jun 26, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 24, 2008
THENTHEREWER
  • 131 Answers
SOURCE: How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Posted on Nov 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Neff Combined oven and microwave
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Nov 09, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
If you don't have your instructions, please reply back with your brand and model number.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Mar 06, 2009
Have a c970-440793 range. Need to replace the oven lamp light. I have the part in from Sears but there are no instructions.
Just slide the wire off of the glass lamp housing cover. It should just pop-off to the side. Then carefully remove the glass cover so as not to break it. Next, just remove the light bulb by unscrewing it counter-clockwise.
Screw in the new bulb (any small 40-watt appliance bulb will work,) hold the glass cove in place, then slide the wire back over the glass cover. The wire should be centered over the middle of the glass, towards you.
Sep 28, 2015 | In Microwave Ovens
Replace oven light bulb in FMV 156D
Hello Jim Rogosheske - To replace light bulbs, first I suggest disconnecting power to the microwave oven at the circuit breaker panel or by unplugging. To release cover, remove the screw on the light cover. Replace light bulbs with equivalent watt bulb available from your manufacturer or a parts distributor that they recommend. Bulbs are also available at most hardware stores or lighting centers. However, it is not recommended to use a bulb larger than 30 watts. Close light cover and secure with screw that was previously removed to release cover. Be aware that light cover may become very hot. Do not touch glass when light is on.
Oct 11, 2012 | Frigidaire FMV156DC Microwave Oven
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
We have a Jenn Air Microwave Over our built in oven. The light is burned out. How do we replace it? it is a jmc 7010ADB. Thank you Jan G
Mine is JMV8166BAS over-the-range model, and yours may be similar. Disconnect electric source (pull plug, or turn off circuit breaker).
1. Locate and remove 2 Phillips head screws on top projecting from cabinet/wall,etc,
2. Carefully & slowly, slide entire front vent 1/4" towards your left simultaneously pulling toward you.
3. Remove vent filter, if any.
4. In very center maybe beneath filter space, locate approx.4" width aluminum colored metal cover, possibly held in place with Phillips head screw.
5. Remove screw, exposing small light bulb.
6. Gently pull back on bulb, replace with identical wattage, 120V bulb from big box or appliance store.
7. Human touch may shorten life of bulb, so carefully push wire prongs into plastic bulb inlet socket using whatever allows you to grip bulb in the limited space.
8. Reverse 5 - 1 for reassembly. Before replacing vent assembly, notice the small notched angle clips on the bottom before aligning to microwave unit, as these were slightly tricky on my unit when inserting & sliding assembly 1/4" toright.
Jun 30, 2010 | Microwave Ovens
How to replace a blown bulb
  • check the size of the bulb required before you buy a replacement bulb. Most use a 40 watt appliance bulb. I
  • Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Open the oven door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back then Gently remove either the wire clip or ring. Since the cover is most likely glass, be careful then Unscrew the entire glass cover similar to a jar lid in older versions of ovens. repeat process if there is more than one bulb..hope this helps pls do let me know
  • Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    How do I replace the light inside the oven that no longer works?
    If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
    See these files:
    http://wwww.microwavedisplay.com/safety.txt
    http://wwww.microwavedisplay.com/disassembly.txt
    The light is usually located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
    Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
    Some use halogen lamps. If so, you must not touch the new one with your bare skin, as the oils will shorten the bulb life.
    For many brands, you can find handy exploded views and order parts by model number here.
    Sep 26, 2009 | GE Advantium 120 Convection/Microwave Oven
    Nov 03, 2008 | Neff H5470 Microwave Oven
    BROKEN GLASS COVER UNDER NIGHT LIGHT
    SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
    May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Bulb cover (glass)...
    Your part number is WB06X10372 for your light cover
    Oct 31, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
    Bulb replacement
    NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
    Aug 08, 2007 | GE JVM3670 Microwave Oven
    Microwave Ovens Logo
    123 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
