Question about HP Compaq nc6000 Notebook
Dear experts, I have HP nc6000. The problem is USB doesn't detect any new device when I attach such like flash memory. Any repair solutions to bring the USB go back to work? Regards, Sok
    New Friend:
  • 38 Answers
Try to do re install
ok
Posted on Sep 16, 2010
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have a 4G mini usb drive but the computer doesn't detect it. I tested it in a Dell printer to scan to usb and works ok. I'm running windows XP in my pc. Do you have a driver to install it or any...
Click Start
Right-mouse click My Computer
Click Properties
Click Hardware
Click Device Manager
Look to see that the USB ports are correctly detected, and that their device-drivers are loaded.
Try a different USB device in your computer; if it also does not work, then you have a problem with your computer, _NOT_ with the PNY flash-drive.
May 12, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How do i get the free music,photos,videos from my PNY 4GB USB 2.0 FLASH DRIVE MICRO SWIVEL ATTACH that i got at Frys electronics
you can just insert the flash drive to the flash drive port in your PC/ Laptop. then the PC detect the new device and it will automatically open and it will be displayed as a removeable drive in My Computer. that folder will be open, you will get your free musics and photos
Sep 14, 2010 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Where can i download driver for hp v165w USB flash
The USB driver installed by default. U need not have to install it separately. If it is not recognised then try to use it on another system, see whether it gets connected or not
Apr 19, 2010 | HP 16 GB USB FLASH DRIVE PRO FULL SPEED...
Trenscend 2FB Pendrive not getting detected
Go to the website for the maker of the pendrive and download the driver for it, the one compatible with your operating system.
Aug 24, 2009 | Transcend (589307) Media
My usb port of my Compaq Armada E500 Laptop no
the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
Jun 03, 2009 | Compaq Armada E500 Notebook
No usb
If your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices.
Dec 29, 2008 | HP Compaq nc6000 Notebook
Transcend 4gb pendrive not being detected in Win XP
my 4gb pendrive is not detecting in my win xp operating system,before 2,3days i repaired my operating system,after that it is not detecting..pls help me
Jul 23, 2008 | Transcend (589307) Media
Transcend 1 GB removeable Pen drive is not detected
The pen driver is ifected with virus.Just format it with CMD and ur problem will be solved
Nov 01, 2007 | Transcend (589307) Media
HP Compaq nc6000 Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
