I wish to replace Bearings and Seals in a LKW74 can you please provide instructions
  • jane_scheggi Sep 16, 2010
    You have given links for a Front Loading Washing Machine ours is a Top Loader.....I gave you the model number kleenmaid LWK74 Where can we find a workshop manual for this
  • Washing Mach... Master
  • 17,129 Answers
These are justt the standard type which you can procure from a tools hardware shop/auto spares.
You must remove the bearing and the seal , normally if there is noise you can clean with diesel and then oil /grease for smooth movement. If the bearing is broken or wobblingg then you can change.
The seals can be reused if it fits tight and the removal does not damage.
However if you think - as the best judge after observations- that it is bad , take them along to the spare shop to comparre with the type available.
The last option is to reach out to your dealer.
Posted on Sep 17, 2010
    Brigadier General:
  • 3,917 Answers
Replacing front axle seals and bearings
I replaced the left front bearings and seals a couple of months back. It is not a problem but be careful as you dismantle the system and of course the reassembly of same. Be sure to replace all bearings and seals as you probably don't want to do this job twice at the cost of parts. No special tricks and relatively easy job. 1601d678-bcb0-4cc6-af13-c2a57bf7d073.jpg
Jun 22, 2014 | 2001 Ford F-250 Super Duty
Replaced front and rear wheel bearings on 2010 fatboy at 15;400 k they were stuffed .are seals no good
Hi Wayne, please be aware that this question has already been asked and answered. Thank you.
Apr 21, 2013 | Harley Davidson Motorcycles
I just replaced the axle shaft seals in th e rear
When you say you can hear the bearings, I wonder what you are hearing. If it only started from doing the seals, I would go back in and see if something is rubbing. Bearings don't go bad quickly.
Jul 05, 2009 | 1989 Suzuki Samurai
Yamaha diversion swing arm and bearings
You can check the manual but its in french..
http://safemanuals.com/user-guide-instructions-owner-manual/YAMAHA/XJ900S-2000-_F
Did you put new seals and bearings in? Have you any parts left over?
Get back to me if you need more help with this.
Jun 19, 2009 | 2000 Yamaha XJ 900 S Diversion
Water leaking from seals under tub; draining water on spin cycle.
Here is a website which might provide you with the internal diagrams and the facility to buy the necessary parts. Just enter the model number in the following displayed page and choose your model from the displayed search list.
click here for Appliance Parts Pros
Else will fetch you the direct link for the machine if you can provide me with the model number and the firm name.
All the best with the machine and in case of further doubts regarding my solution please do post your comments.Would be glad to help you out.Also please do rate my solution as the rating is very valuable.Thank you in advance.
Apr 10, 2009 | Maytag Washing Machines
Suzuki 125rm manual
Find a manual by Googling " Motorcycle service manuals "
or go to www.repairmanuals.com
Installing new crank bearings is not a simple task. you will need a 3/8" impact driver, flywheel puller, case splitter and torque wrench. The top end comes off then the side cases, flywheel, flywheel electrics, clutch, shifter shaft, Crank drive gear and output shaft sprocket.
Split the case leaving the gears on the shafts and the shift drum and forks in place but out of the gearbox. Remove the crank and then remove the bearings from the crank or from the center casings depending on where they decide to stay when the case splits. Remove the crank seals from each center case half. Install new seals then install new bearings into the center casings.
Now just put everything back together.
By the way, now would be a good time to stick in a new output shaft (sprocket) bearing and seal. Be sure the OHC is timed correctly when installing the cam chain. Bad timing = bent valves.
Please rate this answer. Best wishes amcampailla
Mar 14, 2009 | 2003 Suzuki RM 125
Front Wheel Bearing Shot - Please help!
I might have the right size internal bearing puller at work. It looks a little like this... but uses a threaded bolt instead of a slide hamer.
Nov 10, 2008 | 2004 Aprilia Caponord Rally Raid
I need instruction & schematic to replace rear axle bearings & seals on a 1986 4runner sr5
Good news mate!You don't have to touch the bearings at all !!! Just replace the seals, highly unlikely the bearings are toast, had the very same problem and advice from local repairer but another (honest) mechanic suggested to change the seals only and it worked.Remove old seals using a large flat bladed screwdriver taking EXTREME CARE not to scratch the housing, tricky bit is to replace the seals as they have to go in SQUARE to the housing, use a large socket if available or a flat piece of steel to rest against the seal and hammer in SLOWLY AND CAREFUL, ALWAYS SQUARE ! to the housing, take your time and do it a bit at a time, the further in you go the easier it gets, make a note of the final position of the old seal before removal, do a sketch or take a photograph, also take care when reinserting the prop shaft back in the axle housing not to damage the new seal. Good luck !!!
Oct 19, 2008 | 1986 Toyota 4Runner
Indesit washing machine
First of all, what kind of a loud is it making?  Is it a loud squeak, clunk, bang, or jet engine sound?
If it is a loud jet engine sound, then your tumbler bearing is wearing out.  You could try oiling it, but [probably you will have to replace it.  It’s a big job and even if you do it yourself, the best and easiest way to do it is expensive.
I recommend first of all ordering a repair manual.  Or at least see if the parts come with detailed instructions on how to take out the old bearing and install the new.  You will probably have to replace the entire outer drum assembly.  It's much more expensive in parts to do it that way than to just replace the bearings and seals, but much much easier and faster.  Personally, I've replaced the entire drum assembly and also tried to replace just the bearings and seals.  In the end I wasted the money on the bearings and seals and got an new assembly.  I'd recommend just going for the new assembly and saving time.
Oct 14, 2007 | Indesit WA 125 Front Load Washer
Drum Bearings.
I recommend first of all ordering a repair manual. Or at least see if the parts come with detailed instructions on how to take out the old and install the new. You will probably have to replace the entire outer drum assembly. It's much more expensive in parts to do it that way than to just replace the bearings and seals, but much much easier and faster. Personally, I've replaced the entire drum assembly and also tried to replace just the bearings and seals. In the end I wasted the money on the bearings and seals and got an new assembly. I'd recommend just going for the new assembly and saving time.
Oct 01, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
