Question about Asrock K7Upgrade-600 Motherboard
Using asrock k7 upgrade 600 mobo with 2 sata connections , wanting to know if dvd-rom can be used on one of the sata connections or if both are for hdd.
    President:
  • 1,851 Answers
Obviously a dvd-rom can be used without problems. Do you came up with any problem?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 16, 2010
My dell 170L with IDE h/drive & cd rom wont recognise a sata dvd rom ( connected to sata port & power)
Check that jumper settings are done correctly, also check how devices are shown in BIOS.
Sep 14, 2012 | Dell Dimension XPS 400 PC Desktop
I have k8-upgrade-NF3. I tried to connect two SATA CD-ROM to SATA1 and SATA2 ports but the computer restart constantly. The domada is: i can connect cd-rom and cd-burner on SATA1 and SATA2 matherboard?...
you need to change the BIOS setup. Go to the booting menu change the arrangement of your hardware.
1.Primary Disk (Hard disk) 2.CD/DVD ROM 3. Floppy 4.others
then save and exit. Your PC will reboot and MUST detect first your hard drive to proceed to your desktop..
I hope it will help you..
May 21, 2011 | Asrock K8UPGRADE-NF3 Socket754/nForce3...
Want to connect 2nd sata hd but only 2 motherboard connections
u have sata connector. use this connector and power connector . switch on u r system it show drive.
or use extinal case
Mar 23, 2010 | Intel Motherboard
I have asrock prescott 800 ddr400 fsb800 motherboard. i bought a new dvdrw that is sata. is this dvdrw compatible with the mother board? where to connect?
Sorry but the motherboard Asrock 845GV (P4I45GV) doesn't have a SATA controller and there for does not have the ability to connect a SATA CD/DVD-ROM drive to the MB. However you can buy a serial ATA IDE to SATA converter which will allow you to connect you're SATA CD/DVD-ROM drive into an opened IDE port. Provided is a link to you're motherboard;
http://www.asrock.com/mb/overview.asp?Model=P4i45GV%20R5.0 Next, is a link for the SATA convertor;
http://www.startech.com/item/IDE2SAT25-40-Pin-Female-IDE-to-SATA-Adapter-Converter.aspx
Cheers'
Mike
Jan 30, 2010 | Asrock 845GV (P4I45GV) Motherboard
Trying to create a server using the ASRock k7vt6 mobo
turns out the RAID enable in the bios is also used to enable the SATA. but this doesn't mean you have to use RAID to use SATA drives! there's a separate bios to configure the RAID that you can access after the initial boot screen by pressing tab. here, you can delete an existing array or create a new one. deleting the array makes the motherboard see both drives separately, like I wanted. problem solved :)
Aug 01, 2009 | Asrock K7VT6 (K7VT6 RAID) Motherboard
Ecs 6100sm-m mobo connections
you have a few options
1) buy a sata harddrive (faster then ide), use the ide for the second harddrive (backup) and cd/dvd rom
2) buy a sata cd/dvd rom use the ide on both harddrives (1 set to slave)
3) depends on your budget, buy a sata drive + sata cd/dvd rom so your main drive is on sata (faster than ide) then you only have your second drive as your backup drive on ide.
i had the same problem when i rebuilt mine, i went for the seperate harddrive and cd/dvd rom and my 320 gb ide as my backup drive
sorry to jump on this post aswell, see what others think
Mar 16, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
P4i65G - brand new want start.
Try getting a slower cpu, I have a 3.0Ghz P4 with 512mb of ram and it works great, I emailed them about upgrading ram and they said: "Upgrading the memory would not affect the Video card, unless the memory is not compatible with the motherboard, then the computer might not turn on at all."
Oct 24, 2007 | Asrock P4i65GV Motherboard
Asrock K7Upgrade-600 Motherboard Logo
218 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
