Question about GE Spectra JGBP35 Gas Kitchen Range
My ge gas stove works, but the flames just don't seem big enough. even on high, it takes forever to bring a covered pot of water to a boil. The flames seem even, mostly blue with some orange/yellow. any ideas what needs to be adjusted or cleaned (this is a rental house, so I don't know about past use)
  • GE Master
  • 17,130 Answers
There can be poor air mix ( oxygen) for the flame to grow up. so remove the burner and use a good metal brush and air jet to clean off allt he crust and dirt of food lodged into the burners.
Now if the regulator gas fflow is down then your jet is blocked. If so you might have to remvoe the regulator to see that the jet is cleaned out . use a thin pin and airjet to clean.
Posted on Sep 16, 2010
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Tip
How to cook the perfect hardboiled egg
Cooking the perfect hard boiled egg can be surprisingly difficult.
Start by filling a pot with lukewarm water and placing it over a very low heat.
This doesn't need to be the lowest flame setting on your stove top but it should be low.
A good comparison is the flame should be as high as you would have it if you were cooking rice.
Gently place the uncooked eggs into the water.
Pour about a tablespoon of vinegar into the pot. The vinegar will not alter the flavor of your eggs, it will just help the shells peel right off of them when they are ready.
Do not cover the pot.
Keep an eye on the pot for when it boils.
Once the water has come to a rolling boil set your timer for 14 minutes.
Once the timer sounds, remove the eggs with a slotted spoon and place them in a bowl of cool water.
Eggs peel best if they are cold so if you need to peel them right away, do so under a stream of cold water from the faucet. If you can wait, put them in fridge in a closed container so that the sulfur smell doesn't permeate other foods in there. When you're ready to peel them, simply take them out and watch as the shell is removed easily, thanks to the vinegar!
on Oct 07, 2013 | Cooking
Propane stove not heating properly
It would be very helpful if you could give a model number off the unit so we can know exactly what we are diagnosing.
Oct 31, 2013 | Kitchen Ranges
OVEN FLAME TOO HIGH ON A A GE CONVERTED TO LP
You should have a pressure regulator between your stove and your propane bottle. It's probably delivering too much propane at too high of a pressure to the stove.. If you don't have a regulator, THAT would be your problem. A regulator set to too high a pressure makes flame too high and flame may even try to blow itself out. I've remedied this by taking a small cover off the center of the regulator and adjusting a screw.. (Not all regulators can be adjusted.) If adjusting isn't possible, I'd suggest a new pressure regulator (for LPG). Note: A regulator for LPG is NOT set up the same as a regulator for natural gas.
Oct 28, 2013 | GE Profile JGSP44 Dual Fuel (Electric and...
Yellow flame blackening pots and oven
Are you on LP/Propane gas or Natural gas?
Was the range set up by a technician?
Mar 13, 2009 | GE Kitchen Ranges
GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Aug 01, 2008 | GE 36 in. JGP628 Gas Cooktop
Flame on gas hob not correct.
I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
Apr 29, 2008 | Cooktops
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Can't boil water on new Maytag Gas Cooktop
No adjustments.  You will need the correct orifices.  Contact maytag to get the correct ones.  They should send them to you for free.
Nov 18, 2006 | Maytag MGC6536 Gas Cooktop
GE Spectra JGBP35 Gas Kitchen Range Logo
199 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
