Ma monitor viewsonic 17inches one making lot of trobles by hitting the screen osd lock , how to remove it..?
  • 629 Answers
If the OSD buttons does not work and you see a lock symbol appear, try to press the OSD menu button for about 10 to 15 secs and see if the lock symbol disappears. let me know how it goes and if it works, a rating/comment would be appreciated
Posted on Sep 16, 2010
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
Osd lock?
Depending on your monitor:
Solution 1
1. Disconnect power cord.
2. Press and Hold button 1.
3. Plug power cord back in.
4. If necessary, press power button while still holding button 1.
Solution 2
OSD and Power Button Lock Modes
OSD Lock This mode locks all current control settings and prevents access to
the control menus until this mode is unlocked.
? OSD Lock: Press and hold [1] and the up arrow  for 10 seconds. If any
buttons are pressed the message OSD Locked will display for 5 seconds.
? OSD Unlock: Press and hold [1] and the up arrow  again for 10 seconds.
See page 7 of this User Guide for further instructions:
http://www.viewsonic.com.au/support/manuals/files/LCD/Series%20X/VX715-2%20User%20Guide%20English.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
OSD lock should now be cleared.
Feb 04, 2010 | ViewSonic E70f (White) 17 in.CRT...
OSD Lock
OSD lock is a feature which locks the OSD. It can be enabled or disabled by pressing the menu button for 10 sec. It is the lock which locks the On Screen Menu for changing the menu settings.
To unlock press and hold the menu button for 10 sec.
Thank you Sir, Have a nice day.
Sep 23, 2009 | ViewSonic E70f 17" CRT Monitor
When i on the PC this message appears on the screen :OSD LOCK. the type of the monitor i am using is ViewSonic E70f 17" CRT...
To enable or disable the OSD lock feature, press and hold the 1 and the up arrow for 10 seconds.
Jun 03, 2009 | ViewSonic E70f 17" CRT Monitor
At the centre of my viewsonic monitor model:E70fB a message in blue coloured box that"osd lock"and its blinking continously its irritating me
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This might unlock your OSD menu and remove that message from your screen. regards
May 14, 2009 | ViewSonic E70fb 17" CRT Monitor
OSd lock keeps on poping up on my screen, i ihave viewsonic monitor. how can i solve this problem?
You are having a problem with the OSD lock on your ViewSonic Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 28, 2009 | ViewSonic E70f 17" CRT Monitor
OSD lock - I think
This is for Viewsonic LCD, but it's probly pretty similar for you...
raj, rajkumar.ranju@gmail.com
Jul 22, 2008 | ViewSonic E70f 17" CRT Monitor
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
May 22, 2008 | ViewSonic E70f 17" CRT Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
