Load correct paper cassette:ltr - Office Equipment & Supplies
5 Suggested Answers
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
the problem is from Word.
Change the settings: File-Page Setup-A4 (not letter).
IT'S WORKING!!!!
Posted on Feb 08, 2008
tonybudz
  • 162 Answers
SOURCE: Get 3 ALTERNATING messages,and error
Delete printer, reinstall software, error continues reinstall os buy in america next time.
Posted on Aug 12, 2008
AFter we tried everything, the paper we bought was apparently not quality controlled and mixed with different weights of paper that caused the error. We purchased another brand and have had no problems so far...
Posted on Dec 02, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Posted on Dec 27, 2008
My printer is i-sensys MF4150. It prints one page then stops the error light flashes red and message 'load correct paper cassette : ltr ' appears on the LCD screen.I print 1 page then I...
Dear
Pl. select the paper size ( as mentioned on the paper packet) on computer on click START-PRINTER AND FAXES(new window opened)-(right click on printer icon) PRINTING PREFERENCE(new window opened)-select PAPER -paper option (here the paper size to be selected- APPLY. This may set the paper size default.
Thanks.
Feb 03, 2015 | Office Equipment & Supplies
Canon MF3220 LOAD CORRECT PAPER CASSETTE:LTR
the ACE Thanks its work for me
edrickkp
TANZANIA
Mar 29, 2012 | Canon Office Equipment & Supplies
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
We tried printing and copying with the setting set at LTR and LTR-R and we checked the paper tray and every time we make a copy or print it prints out the entire document perfectly centered across the...
It seems to me to be a problem of the Blue paper cassette size dial is set wrong. First see what the settings are from the display by pressing the paper select button. Most people have it set for the upper cassette to be LTR ( 8 1/2 X 11 inch paper - length running from front to rear in the cassette ) and the lower cassette to be LTR-R ( 8 1/2 X 11 inch ) or Legal ( paper length running left to right). Check to make sure the blue dial agrees with what's in the cassette. Try doing the testing by putting the paper on the glass first and closing the top. If this is correct and the problem is in the Documnet feeder then one of the raised flags may be broken or the sensor bad. The left one is for letter, the second one for LTR-R or legal and the third is for 11 X 17. The opening and closing fo the side guides also helps to determine paper size. Hope this helps you.
Nov 30, 2010 | Canon imageRUNNER 2270 Copier
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Paper cassette error
This meen the paper dial selector in the drawer is set for letter size paper,set it to the correct envelope size.I suggest you use the manual bypass for the evelopes.
Sep 25, 2009 | Canon imageRUNNER C3200 Copier
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Dec 01, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
341 people viewed this question
k24674
jasbo
jasbo
