My canon ip2770 continuous printer had a problem with the ink cartridge...it says the cartridges no longer have ink but the tank is still full..please help.!!!1
SOURCE: Canon Pixma IP600D - error code 6502
THANK YOU VERY MUCH FOR THE HELP. THE CANON PIXMA iP1000 SEEMS TO BE WORKING WELL. LET'S SEE HOW LONG.
GREAT FixYA Saves me from too much worrying. I have 8 printers inside the office: Canon 4, Epson1 HP 2 and 4 computers and 5 scanners.
Thank you for the email reminding me if I need help.
This is documentations time in CAFAG, Inc.
The Executive Officer - Lydia
Posted on Oct 05, 2008
SOURCE: cannot recognize ink cartridge
I had the same problem. I was using original brand cartridges and it was still not working. Here's how I got it to work. I recommend doing each step and then trying to print a test page to see if it is working.
1. I used a Q-tip with Isopropyl Alcohol and cleaned the gold contacts on both the cartridge and the mating contacts in the printer.
2. Then from the Setup Menu, I found a menu called Tools. From there I ran "Align Print Cartridges".
3. From the same menu I also ran "Clean Print Cartridges"
4. I then ran a few test prints by going into the Setup Menu and then choosing "Print Report" and then selecting "Self-Test Report". It prints grid patterns in black & white as well as magenta, yellow and blue. The black grid pattern had some missing lines until I printed this report a few times.
5. I made a few photocopies and now the printouts no longer have large stripes of missing ink as it did in the earlier steps.
Good luck. Hope this helps.
Posted on Dec 03, 2008
netrocker
  • 162 Answers
SOURCE: I have installed Continuous Ink
Press resume button for 5 secs. This works for other canon models using cis.
Thank you for using fixya, have a nice day!
If this helps, please rate me :)
Posted on Jan 17, 2011
informatica
  • 1114 Answers
SOURCE: canon muti-pass MP360 INK TANK FULL
I believe what you are seeing is "WASTE INK TANK FULL"? This means that the tank that collects the waste ink from cleaning the head is full. You can read more than you ever want to know on this subject on the following link: http://www.fixyourownprinter.com/forums/printer/38697#1 These are the steps to clear the message by reseting the counter: 1)Printer on, press Additional Functions, Scan, Copy, Scan Now you should be in service mode from there for waste ink tank reset 2)Select Test mode which is like the last available selection 3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other options this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button The menu will now say EEPROM Clear Select Ink count which is option (0) and press set Your done!
Posted on Aug 03, 2007
SOURCE: Canon MX850 will not print from small Black Ink Cartridge
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Posted on Oct 02, 2009
Canon ip2770
If you did not install the same brand of cartridges, the system will not recognize. If you know there is ink and the printer works, keep going.
Aug 03, 2013 | Office Equipment & Supplies
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
Canon ip2770 does not recognize ink
Are you sure you bought the PROPER ink cartridge for your model? If the cartridge is the correct one, maybe it is defective, else the problem is with your printer and it should be repaired.
Try to verify if your printer works with another cartridge before taking it to service
Feb 01, 2012 | Canon Pixma iP2700 InkJet Photo Printer
Ink cartridge of canon ip2770 cannot be recognized after I replace the new cartridge
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Sep 23, 2011 | Office Equipment & Supplies
Error 5200 occured while printing. And the black catrige does not recognised
Error code 5200 represent print head or cartridge temperature exceed specified value. It may be caused by the following condition: ink empty or usage of refill ink.
Please check which cartridge indicated by this error and replace it with new one. For Canon Pixma iP2770, this problem frequently caused by an empty CL811. Please refer to Canon Pixma iP2770 Service Manual for details.
Source:
Printer Clinic
Printer Manual
Jul 30, 2011 | Canon Pixma iP2700 InkJet Photo Printer
How can i refilkl the ink of my printer canon pixma ip2770
open the top lid cover.
The printer carriage ink will position itself in the middle.
Lift up the cover and gently remove the ink cartridges upward.
Examine the ink cartridge. Drill a small hole at the mid section at the top of the cartridge. Small enough for the syringe carrying the ink to get in. Do not push the needle of the syringe inside so far, cause this may damage he foam inside the cartridge. Press gently and slowly the ink in the syringe. After filling up the cartridge , do not forget to cover the small opening as this may dry up the ink.
Return back the cartridge to he printer.
After that reset the printer. Press and hold down the resume button and wait untill the printer restart itself.
Hope it helps.
Nov 25, 2010 | Canon Pixma iP2600 Photo InkJet Printer
How to refill a canon lbp 2900 printer cartridge
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. 2
    Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. 3
    Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. 4
    Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. 5
    Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. 6
    Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Nov 10, 2010 | Canon LASER SHOT LBP-2900 Printer
I have the error message that it can not recognize the ink cartridge and it is blocking me from using the macine in any function. I have removed the ink cartrdige and it still says it cannot recognize...
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Oct 08, 2009 | Canon MP610 Photo All-In-One Printer
Error U043 - Ink Tank Cannot be recognized
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Apr 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
1,581 people viewed this question
jasbo
jasbo
