Question about D-Link Computers & Internet
Wireless router I have the router but not the set up disk
  • 2 more comments
  • designergirl May 20, 2008
    Hi there, I have the same DIR-625 Wireless Router. Here's my problem. My internet provider went down and when it got back up, somehow my router wasn't working anymore so my laptop couldn't connect. I tried resetting the router by holding down the side button...it lit up blue and flashed for a few seconds. It has been awhile since I set up the configuration for the router and of course, I've forgotten my password. When I login to the configuration interface using Admin and a blank password it doesn't allow me access...it will allow me to get in using User and a blank password, but it won't allow me to change my password to something I can remember. Can you please simply tell me how to change my password (without remembering the old one)....Do I have to completely uninstall the router and re-install? Please let me know. Thank you! -- Stressed in Winnipeg, MB ;)
  • megstar525 Jul 18, 2008
    I have the same problem. I have a Linksys D-Link DI-614+ and i don't know the username and password to configure it to my computer. I have tried admin, admin; admin, blank; admin, password;....everything. Do you have any idea what they could be?
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Do you still need help setting up your router? The posted solution for this was wrong. The default user name is admin but the default password is nothing ( just leave blank). If you need more help I need your model # and your rev level. Either on the bottom or the back. Will say REV A,B,C, etc. Don't think D-Link has disks to download but they will have quick setup guides. Either way let me know what happens. (Also, you do not want set this uo via wireless. Use a cable and then you can run wireless once it's setup)
    Jeff
  • Jeffrey Pemberton
    Hi Candace - What's the make and model # of your please? Thanks.
    Jeff
    Genius:
  • 1,224 Answers
In internet explorer search bar type in this code here 192.168.0.1 this is your fixed router ip this will bring up the screen for router protocol
it will ask for name and password unless you changed the password and name it should still be normal
type=admin for name
type=password for password this will give info on your routers and specs
also windows now has a wireless network setup so i believe you should run that to get your wireless router up and running
Posted on May 17, 2008
How do i hook up my d-link dir 615 to a different computer without the disk
You need to go into the D-Link wireless settings to get the SSID and encryption settings and configure the wireless card in the different computer with these settings.
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)You can now change the default adminpassword.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 07, 2012 | D-Link DIR-615 Wireless Router
Lost disk to my belkin router model f5d7234-4 how can i uplaod the program
You can configure your router without disk too.
Follow below instruction.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 05, 2010 | Gateway 802.11g Wireless DSL/Cable Router...
Unsecured connection Need to know how to add security to my dlink wireless router so that my wireless internet connection is not used by others.
there are usually two ways to do this. one, your router should have came with a disk. if you run that disk it should walk you through step by step. if no disk, try typing 192.168.1.1 into the address bar. this should take you into the router diagnostics. in this, you should see some tabs about setting up the wireless settings. if neither one of these work, the best bet is probably calling dlink tech support for help.
Oct 19, 2009 | D-Link Computers & Internet
I bought a wireless router wrt54g and I dont have the disk to install it so what can I do?
You won't need the disk.  You can plug your computer directly to the router.  From there it should receive an IP address.
Go to Internet Explorer>192.168.1.1>enter credentials, then you can setup your wireless settings.
Use window to manage your wireless services.
Feb 01, 2009 | Linksys Wireless-G WRT54G Router
Need disk and instructions
You don't need a disk to set your router
You can get help here:
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Then do this:
Setting wireless network on Win XP
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Oct 31, 2008 | D-Link DIR-625 (790069292637) Wireless...
No connection to internet
First thing you need is to run the set up disk that you should have received when you purchased modem. It should run you through the steps. This should also allow you to set up your wireless connection also. It should also provide you the access code for your wireless security. Basically what this does is prevent unauthorized access to your network. Whenever you add additional computers you will need to set up each individually and enter access codes. If you don't have a disk you might need to contact manufacturer to get a replacement disk. Good luck.
Oct 18, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
Wireless router
If you have a computer wired to the router, Try this steps.
1.Open a browser and then go to http://192.168.1.1
2. Username admin and password is password
3. You should be able to access the router's utility page then and get the wireless settings of the router.
Once you get the wireless settings of the router, just connect to the name(SSID) you set up and then connect to it.
Apr 25, 2008 | NetGear WGT624 Wireless Router
Will a set up disk for a WRT54GS v.6 Linksys wireless router work to set up a v.1 router?I CANNOT use or make Firma-ware, or whatever that is, work. Where can I get a driver disk for a WRT54GS v.1 Linksys...
You really don't need the disk. Just plug the wires in and push the square button on the left hand side with the Linksys logo and that will set it up. Just wait until the light is a steady orange color. It will blink white while it's setting up. It could take a couple minutes.
Nov 09, 2007 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
338 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
