Question about Canon imageRUNNER 2000 Copier
My canon ir 2018 is asking me to load correct paper in the tray even when the paper size is correct and all the settings are correct. It would print one copy then ask to load paper, i pull out the tray and re sit the paper, push it back in and then it will continually print the same paper more than 10 time What should i do?
    Sniper:
  • 51 Answers
Check the proper orientation of the paper. For example, if you are loading A4 size. In your tray you can find 2 A4 size. Select A4R in you want to position your paper Landscape or A4 if portrait.
To verify also the correct paper size, put your paper on the platen glass. Markings on the two sides of the platen glass shows the correct paper size.
Posted on Oct 05, 2010
Canon ir 2420L loud correct size paper how to loud paper
Dear
Pl. check the setting of the copier to the paper loaded(size and orientation), the tray selector switch,paper drive rollers/guide.
thanks
Jan 06, 2015 | Canon Office Equipment & Supplies
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
I tried to copy with my canon ir 2018 and my canon copy a half of the contents,and tell me load correct paper
I believe you don't have the paper size slide on the front of the paper cassette correct. Look at the slide carefully because it also has the paper direction picture along with the size.
Jun 14, 2011 | Office Equipment & Supplies
I have canon copier ir c2100,i cant print becouse when ever i try printing it displays as out of paper but there is a lot of paper too what do i do
Try to put paper into the manual feed tray and let it print. I would check to see what you default tray is set to... It may be to the manual feed tray and make sure you have the correct paper size for your paper trays
May 16, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
Canon ir 2016 is asking paper size, while paper in tray are correct. what is the problem
It could be several errors.
1) do you have paper size senzor on paper tray set according the paper in?
2) It coud be that you have problem with paper pick up clutch
3) check the registration sensor flappers, door on the left of the tray flapper,...
4) try to clean the rollers
5) compare your paper lenght with some other paper manufactors
May 17, 2010 | Canon imageRUNNER 1023iF Black and White...
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
Printer says : paper load but in spanish ;: Carga Papel. I can copy but cannot print. This is strange as the paper is in
The printer is asking for a spesivic tipe of paper size that is not loaded in the machine,cancel that print job,check that the paper settings on the program you whant to print from is correct,and reprint again. If that does not solve the problem you can check on the printer driver on the computer if the paper size settings is correctly set there.
May 11, 2009 | Canon iR 2016i Black and White Copier
Lexmark t642 load mp feeder with letter
The reason that your printer is asking you to load paper into the MPF is that it doesn't think it has that size paper in tray 1 or 2. Make sure that the green paper guide in the paper tray that you want to print from is latched in the correct position. This guide tells the printer what size paper is in the tray. If you have it even slightly out of position you'll get this message.
Mar 11, 2009 | Lexmark T642 Laser Printer
My Canon ir c2100 has a paper jam issue.
Have you tried to run copies from both paper trays? Will it jam in the same spot with both trays? If one works, but the other jams, it may be as simple as making sure the paper tray is set to the correct paper size? Is it set up in the paper tray as LTR, but the tray is saying LTR-R on the display. If so just change the paper size knob to the correct size. Also, if it stops in the same spot with all of the trays, look for something blocking it. Also, try to cheat the side door and make sure everthing is turning correctly.. Good Luck...
May 22, 2008 | Office Equipment & Supplies
Canon imageRUNNER 2000 Copier Logo
1,994 people viewed this question
old marine
old marine
