Question about Bosch SHU5316UC Dishwasher
How do you remove the top of the S510 dishwasher? We have laid new tiles and it will not fit back in the space with the top on. Thanks Loraine
  • 901 Answers
Check whether you can adjust the machine legs. Removing the top, it depends on the design.
If removable moulded or laminate top is provided :
Watch for the fixing screws at the back of the machine. If screws are there remove them. Slide the top forward or backward and remove.
Posted on Sep 16, 2010
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
Tip
Ceramic tile installation
To Start a Ceramic Tile Project:
1st: Figure out the Size of the Room-Length x Width. This will give you the suare Footage of the Room, and will Determine the amount of Materials You will need for Preparation of Floor before Tile Installation.
2nd: Pick out the size of Tiles, and the Color you wish to Purchase(Decide if it is a High Traffic Area) Tile Comes in different Grades, and if a High Traffic area, you will need a Higher Grade Tile.
3rd: Materials needed for Preparation- Hardy Backer Board(1/2"-3' x 5'). HardyBoard Screws, Unsanded Mastec, Spacers-Depending on Tile Spacing/size of Tiles, 1' x 4' boards. (Tools Needed- Drill, Chalkline, Measuring tape, 3/16 x 3/16 Trowel, 1/4 x 1/4 trowel).
Installation; )Preparation) 1- Apply a 3/16 x3/16 trowel of Unsanded mastecon floor before laying the Backerboard. Screw the Backer Board to the floor recessing screws. (Never have Backerboard meet with 4 pices meet together, off set each piece of backerboard during Installation). After sweeping the room, use a trowel to fill screw holes with unsanded Mastec. Tape all Joints and fill with un-sanded Mastec.(Let Dry for 24 hours).
Tile Installation:- 1st- Sand Mastec used for joints, and screw holes. 2nd- Sweep roome very good and vacuum very well. 3rd- Measure each wall to find the Center Point of the room.(I prefer nailing a board down across one side of the line to keep tiles straight, and butt tiles to the board, and put spacers in between tiles). I use a 1/4" trowel to butter tiles before laying. With using Spacers, buttering tiles, laying tiles.( I prefer using a 2 x 4 and tap tiles across with a rubber Mallet to keep all tiles same heigth). Let One side tiles laid for 24 hours. 4th- Then do the same thing with other side of line.
Finishing Project: Once all the tiles are set, and all spacers removed. Mix up color of Choice unsanded Grout, and follow Manufacturers mixture Specs. Use grout Float and fill Spacing between Tiles. Let dry for 15 minutes. Use bucket of Clean water and Big sponge rinsing frequently removing all Grout from Tiles. Let dry for 30 minutes, and clean tiles again with Clean Water. Let set overnight. Next day, take Clean towel and rub haze off the tiles. Lastly, Seal Tile and grout.
Enjoy your project, and the Satisfaction of doing it yourself. Hope i was some help!!
on Feb 06, 2012 | Ridgid Saws
I have a built in Hot point dishwasher that is 15 yrs old. I will be putting a ceramic tile floor down. Will I be able to pull the dishwasher out with no problem?
thank you for thinking about and asking that..i have serviced so many dishwashers where their was new flooring and they were tough to pull out..the best thing is remove the lower panel and raise the legs,and even if it is scrap from a peice of tiles that is cut slip that tile under then lower the legs so the legs will be at the same level of the floor and come out easily in the future..their is no need to even use tile mastic or grout under the dishwasher since it will be hidden by the panel
Aug 24, 2011 | Hotpoint Dishwashers
Remove the top from free-standing-dishwasher bosch sgs43c12
hello martin - yes you can remove the top. And no, it will not harm the dishwasher funcion.
Aug 02, 2009 | Bosch 24 in. SGS43C12 Classixx...
Mouse inside housing
Ouch, I wish you the best of luck with this.....
You will definatly have to slide the unit out from under the counter, dont forget the two or three screws at the top of the washer to the cabinets or counter, and if it has side panels over the insulation, you will have to access the first set of screws from underneath the dishwasher. Sometimes removing the front door helps. Careful not to lose screws, and expect that you'll have to re adjust the unit to fit back under the counter by leveling it. Do your best not to mess up the current setting of the levelers unless there is a floor height difference that will prevent you from pulling it out. (i.e. tile kitchen, and no tile under dishwasher)
When you slide it back, make sure not to pinch hoses, (feed or drain) level it as best as possible, and replace all screws!
Jul 30, 2009 | Kenmore Dishwashers
Door rubs on new tile floor. How do I fix this.
The best way to solve this is to remove the door and re-install it at the desired height. Last resort - cut jambs off, raise the threshold. cut the top off the door, reblock it and move it up in the jamb. Yes, I have done this before, when there was no room to raise the door. I managed a door shop and we cut and reblocked many steel doors at the top. I like to use construction adhesive to hold the block.
Jul 22, 2009 | Dishwashers
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Replace dishwasher / counter tops are not standard
i have had that problem before and used a saws-al and cut the legs and what ever else i needed to get that puppy out.the question is will your new one fit?in my case most all i ever tried to install i got them in.and i have done a hundred or so
Feb 03, 2009 | Whirlpool Dishwashers
Dishwasher opening
You can remove the feet from the bottom of the dishwasher
Jan 05, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Bosch SHU5316UC Dishwasher Logo
509 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
